Bx 23 front axle leaking oil
   / Bx 23 front axle leaking oil
I think I will replace the seal how hard could it be..
   / Bx 23 front axle leaking oil #12
If mine were leaking like that I would put a seal in it and be done with it! I done my B and it is not much of a job, less than $50.00
Apparently it isn't 12 degrees there.
My L4200 always leaked a little - 75W90 just about stopped it. It started leaking fairly furiously again after a hard-working summer. I filled it up with 85W140 and keep a cup under the hub when I park it to catch the drool. It fills up a cup (spray-paint lid) after several weeks, but I just checked it and the level was still fine after 3 months. 1.5 gallons is a lot of spray paint lids, I guess :).
I'm planning on doing the seal when it gets warm.
JayC
   / Bx 23 front axle leaking oil #13
It may also be cracked as noted above, in that case I would want it replaced so I did not have failure later on.
did it require any special tools? Or - just sockets/wrenches? I have the problem as well, but it's not too bad, so I've been putting it off.
   / Bx 23 front axle leaking oil #14
   / Bx 23 front axle leaking oil #15
Nothing special required but you will need GOOD snap ring pliers. I got by the first time with the pliers I had but got a good set for the other side and it made it a bit easier.
   / Bx 23 front axle leaking oil #16
Thank you. So - by a "Good" set of snap ring pliers, are you saying Snap-on/MAC brand quality, or Craftsman/Kobalt quality?
Edit: Also - how many beer project is it?
   / Bx 23 front axle leaking oil #17
Edit: Also - how many beer project is it?[/QUOTE said:
I'm guessing .....6 to a 12er... depending how thirsty u r:licking:.
   / Bx 23 front axle leaking oil #18
Good as in substantial not the cheap sheet metal stampings.
Oh.....I do not drink while working but it took 3 beers after the job was done:cool:
I am guessing at 1 to 1.5 hours per side????
   / Bx 23 front axle leaking oil #19
Excellent. Thank you!
2014 Dodge 5500 4X4 Bucket Truck (A51039)
2014 Dodge 5500...
1982 LeeBoy Motor Grader (A51039)
1982 LeeBoy Motor...
2011 International School Bus (A49461)
2011 International...
THIS WILL BE A LIVE VIRTUAL ONLINE AUCTION! (A50657)
THIS WILL BE A...
2013 CHEVROLET SILVERADO 2500HD (A50854)
2013 CHEVROLET...
2006 Ford F-150 Pickup Truck (A48081)
2006 Ford F-150...
