Bx 23 front axle leaking oil
   / Bx 23 front axle leaking oil
I think I will replace the seal how hard could it be..
   / Bx 23 front axle leaking oil #12
If mine were leaking like that I would put a seal in it and be done with it! I done my B and it is not much of a job, less than $50.00
Apparently it isn't 12 degrees there.
My L4200 always leaked a little - 75W90 just about stopped it. It started leaking fairly furiously again after a hard-working summer. I filled it up with 85W140 and keep a cup under the hub when I park it to catch the drool. It fills up a cup (spray-paint lid) after several weeks, but I just checked it and the level was still fine after 3 months. 1.5 gallons is a lot of spray paint lids, I guess :).
I'm planning on doing the seal when it gets warm.
JayC
   / Bx 23 front axle leaking oil #13
It may also be cracked as noted above, in that case I would want it replaced so I did not have failure later on.
did it require any special tools? Or - just sockets/wrenches? I have the problem as well, but it's not too bad, so I've been putting it off.
   / Bx 23 front axle leaking oil #14
   / Bx 23 front axle leaking oil #15
Nothing special required but you will need GOOD snap ring pliers. I got by the first time with the pliers I had but got a good set for the other side and it made it a bit easier.
   / Bx 23 front axle leaking oil #16
Thank you. So - by a "Good" set of snap ring pliers, are you saying Snap-on/MAC brand quality, or Craftsman/Kobalt quality?
Edit: Also - how many beer project is it?
   / Bx 23 front axle leaking oil #17
Edit: Also - how many beer project is it?[/QUOTE said:
I'm guessing .....6 to a 12er... depending how thirsty u r:licking:.
   / Bx 23 front axle leaking oil #18
Good as in substantial not the cheap sheet metal stampings.
Oh.....I do not drink while working but it took 3 beers after the job was done:cool:
I am guessing at 1 to 1.5 hours per side????
   / Bx 23 front axle leaking oil #19
Excellent. Thank you!
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
PALLET OF BRAKE AND AXLE PARTS (A50854)
PALLET OF BRAKE...
TANNKO  130BBL VAC TRAILER (A50854)
TANNKO 130BBL VAC...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A51039)
2020 New Holland...
2007 MACK GRANITE ROLL OFF TRUCK (A51222)
2007 MACK GRANITE...
Flat Deck Trailer (A50322)
Flat Deck Trailer...
