PTO turns for a few seconds after being disengaged
   / PTO turns for a few seconds after being disengaged #1
neilbedwell
Hazard, KY
Kubota L2800
Yesterday evening I hooked up the tiller to till a small strip of the garden to plant some peas. When I came out of the garden and disengaged the PTO I noticed something. Here's what I did:
1. lifted the tiller up out of the dirt. PTO was still engaged and tiller was still turning
2. I pushed the clutch in all the way and disengaged the PTO. The tiller stopped turning while I had the clutch pushed in.
3. I let back out on the clutch and the PTO and tiller started turning again. It ran for about 2 seconds then stopped.
So, is this normal? My tractor is a 2010 L2800 HST 4x4 with about 23 hours on it. I can't say I have ever noticed this happening before but it's entirely possible. I was able to make it do it several more times as I engaged / disengaged the PTO to try and see if it kept on doing it. Most of the time it did it, a few times it did not turn after letting back out on the clutch.
If this is normal behavior that's fine. I've just never noticed it before. Thanks guys!!
   / PTO turns for a few seconds after being disengaged #2
Mine still turns after I disengage also, so I think its normal. Its especially noticeable when I have my mower on. The blades will continue to turn for a while.
   / PTO turns for a few seconds after being disengaged #3
Your PTO cable may be sticking, a little cable lube may fix it. Mine went through a phase where I had to go under the tractor to manually disengage it but after spraying a little lube in the cable jacket, good as new.
   / PTO turns for a few seconds after being disengaged #4
It's probably just inertia of all that rotating mass, but try it with no implement hooked up. I expect it'll stop considerably quicker.
BTW, my 60" rotary cutter takes more then a minute to stop...that's due to the weight of the blades plus the high rotation speed.
   / PTO turns for a few seconds after being disengaged #5
Hmm.. he's saying the tiller has stopped with the clutch pushed in and the PTO disengaged, then when he lets the clutch out (PTO still disengaged) the tiller starts turning again for a few seconds before finally stopping again.
Maybe a sticky clutch pack in the PTO clutch?
Sean
   / PTO turns for a few seconds after being disengaged #6
   / PTO turns for a few seconds after being disengaged #7
Or the PTO brake not functioning (assuming his tractor has one).
L2800 does not have one.
There is a slight rake on the PTO cams, so unless the implement is driving the PTO a bit it may not want to disengage easily.
When I sheared a pin on my snow blower the PTO did not want to disengage on my L3400HST. After putting in a new shear bolt the PTO disengaged right away again. With the pin broken there was not quite enough inertia to unload the cams.
This is why I always disengage at the same time as I push the clutch in.
   / PTO turns for a few seconds after being disengaged #8
Mine still turns after I disengage also, so I think its normal...
THIS IS NOT NORMAL @#$%^&* NOR IS IT SAFE!!!
Lube the cable... So kubota hasn't fixed this issue either...
I dug a hole with my tiller in my shed... with the PTO out of "gear".
   / PTO turns for a few seconds after being disengaged #9
Here is a picture of the PTO cams used in the L2800 L3400 HST's. Once they are engaged they tend to stick a bit. When the old style is unloaded they ratchet. The old style is a one way clutch. When they are unloaded they will disengage much easier. The newer models have clutches that don't ratchet.
There are also problems with cables. I lube my cable every 100 hours or so. There is also a new style lever bracket that is supposed to take some of the bend off the cable. I have not installed that.
I have always thought if I have problems with the cable I would design a manual lever at the bottom of the floor pan that does not use a cable. So far after 5 years and 300 hours I am still OK.
OK, so I guess the first thing I need to do is lube my cable. I will unhook my tiller and test the PTO without anything hooked to it to see if it does it then. The tiller might still be rotating after I push in the clutch and I just cannot tell from the seat. When I let back out on the clutch you can feel the tractor shake like it's running the PTO for a couple seconds then it smooths out and you can hear the tiller stop. Would cold weather make it slower to disengage? How do I lube the cable? What lubricant do you recommend? Thanks guys for all the replies.
2001 Sterling L7500 Heil 12Yd T/A Dump Truck (A51692)
2001 Sterling...
2022 CATERPILLAR 980 WHEEL LOADER (A51246)
2022 CATERPILLAR...
2004 TerraGator 8104 (A55301)
2004 TerraGator...
2006 S/A Dry Van Trailer (A55788)
2006 S/A Dry Van...
Swict 84" Bucket (A53316)
Swict 84" Bucket...
2005 Bomag BW266 Double Drum Roller (A54865)
2005 Bomag BW266...
