tree spade
   / tree spade #11
it's so easy when you have the spade for making the new hole, dig the tree, carry it to the hole and drop it right in.
i've bought trees from the guy that helped me move some of mine, and it wasn't as much fun digging my own holes.
   / tree spade
my first four trees:
   / tree spade #13
Looks like the tree spade does a good job moving the cedars but I gotta ask.... for a windbreak shouldn't you be re-planting them closer? Or do you plan to fill in the gaps with more trees? Or maybe the cedars will fill out the gaps as they grow and branch outward??
   / tree spade #14
Hello beavis, Here is a few shots of the tree moving that goes on here in the spring and occasionally in the fall. A 36 inch lemar spade on a jd 322 track machine and me little 790 loadn' trees to get hauled to a customer:thumbsup:
   / tree spade
This is the beginning of the first row, with the trees being approximately 12' apart. There will be a second row planted behind, that will be offset (left to right) by 6' which will fill the gaps. I guess it will look like a big zig-zag if looking at it from above. As the trees grow and fill in; a pretty good windbreak should be established.
   / tree spade #16
Local Ag extension office is wonderful help in laying out windbreaks. Here, it is a minimum 3 rows of trees, staggered. They also recommend shorter trees in front(or rear)to give a ramp effect over the top. Some is better than nothing, anyways.
   / tree spade #17
Here's a mowing thought to those reading this. If you mow so close that your tractor tire brushes the edge of the trees, the impact will "prune" the tree and not allow growth to continue where the tire contacts the tree. This didn't seem to be a big issue when we lived in Maine where it was wet and cool but it sure is here in dry and warm Ohio. If anyone wants I can post photos.
A further thought to windbreaks is to plant a row of (northern white) cedars/Aborvitaes in addion to the windbreak. They grow really fast, espcially with fertilizer and add to the windbreak by the variation in height. I plant those on a four foot center and have photos of this as well.
The addition of windbreaks and trees has been the greatest addition to our land that I have done. They take time to grow but water, fertilizer and pruning speeds up the process and before you know it you have something to admire.
   / tree spade
Moved a total of 13 trees last spring and to date, all have survived. I was unable to move any last fall because of no rain and HARD SOIL. Hooked it up this past Wednesday and moved 8 more. Have got another dozen or so before I conisder the windbreak done.
   / tree spade #19
Having a 34" tree spade sure helps and moving in the spring is a real plus.
How close are you putting them in the row and what kind are they?
How long does it take to dig and move a tree?
   / tree spade
they are eastern red cedars (wild pasture trees that most farmers cut down when clearing out a pasture) I've got two rows that are offset. bascially 6ft apart. It only takes about one minute to dig the hole/pull the plug and the same short time to set the tree. Time is consumed when I drive 1/2 mile to the pasture where I'm getting the trees from and also when you put dirt around the base of the tree and water....................
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A55301)
Michelin CARGOXBIB...
High Lift Ratcheting Off Road Utility Farm Jack (A55787)
High Lift...
2007 American Signal S/A Solar Towable Message Board (A55787)
2007 American...
Toro Mower (A50324)
Toro Mower (A50324)
1985 Miller Wildcat 350-D Welder (A54811)
1985 Miller...
2006 VOLVO VHD TANDEM AXLE REAR DISCHARGE CONCRETE MIXER (A56129)
2006 VOLVO VHD...
