Terra-Dome Earth Shelter Build
   / Terra-Dome Earth Shelter Build
We had a few warm and dry days, so we cleaned and sealed the leaks on the roof using up the last of our Ecoline-R. We are leak free in the areas where we reapplied several times. We also began working around the house covering the strap holes on the horizontal walls with the mesh patches and the Ecoline-T. We began installing the kitchen laundry room wall. We are pleased on how the pipe holes, fasteners and glue worked. We will continue anchoring and gluing our pressure treated to the concrete floors, walls and ceilings.
If you didn't install a high quality vapor barrier on top of a deep bed of crushed stone, completely taped and sealed around pipes and other protrusions like stated below you may have moisture issues related to the below.
Based on the response to this post I would say I am sorry if I offended anyone. I have done some research on the concrete moisture problem and this is why we went to such extreme to prevent these problems. I believe if you follow the method using under slab French drain, crushed stone, a quality vapor barrier taped and sealed your slab will be free of serious moisture issues. I found a better method of waterproofing your concrete. It is called crystalline waterproofing. This technology turns the porous concrete into an impermeable barrier. The result is a structure with reduced cracking, self-sealing and waterproofing abilities which provides a powerful defiance against water damage and corrosion of reinforcing steel. Replaces unreliable exterior membrane systems, Penetrates deep into concrete, Self-seals hairline cracks, Reactivates in the presence of moisture years later, Effective against hydrostatic pressure, Waterproofs from any direction, Impervious to physical damage and deterioration, Easy to apply. Only thing I don't know the cost.
   / Terra-Dome Earth Shelter Build #633
Hey Sam,
While I know a lot more about concrete than when we started our house, I still don't know beans. All I noticed in your post was that it was technical details on concrete and mine was already cast. I sure didn't see any issues with your post.
Steve
Maine
Our local electric co-op was scheduled to begin installing our three poles and also replace an existing pole that begins the feed. They got a late start and only installed two of the four. Our rock prevented them from getting the third pole in place. The will need to blast to get this in place. We got some more of the framing in place.
   / Terra-Dome Earth Shelter Build #636
Is the plan to also have solar panels? Or stay grid tied?
   / Terra-Dome Earth Shelter Build #638
Our utilities up use a core drill for the rock / pole problems but blasting is more fun!
Sam in the last picture is that a door frame were the plate is cut?
If so I do the samr thing while framing but I usually cut the bottom of the plate so I dont have to hit the floor with the saw to clear out the waste.
tom
   / Terra-Dome Earth Shelter Build #639
If so I do the same thing while framing but I usually cut the bottom of the plate so I don't have to hit the floor with the saw to clear out the waste.
tom
I meant to cut the bottom but got it mixed up. So I also put a small cut on the bottom.
3 Point 5 1/2ft Metal Screen Cargo Carry (A51573)
3 Point 5 1/2ft...
2014 AMADAS SPC-6-36 LOT NUMBER 211 (A53084)
2014 AMADAS...
2018 Forest River Grey Wolf 26RR Lmtd Toy Hauler (A52384)
2018 Forest River...
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A52577)
2018 KENWORTH T680...
Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A51691)
Godwin CD150M 6in...
50ft Fuel Line (A51573)
50ft Fuel Line...
