Buying Advice Kubota RTV 1100
   / Kubota RTV 1100 #101
My 1140 doesn't idle high at all. Had it a month or so.
   / Kubota RTV 1100 #102
Timswi,
Does your 1100 idle kinda high? Mine just seems like it's very high.:confused:
It may be a Tier 3 engine, I think one of the changes was idle speed to meet the new tier. Or you may just have the throttle lock pulled out.
I run mine on high idle anyway to boost the pump pressure and takeoff power.
David Kb7uns
   / Kubota RTV 1100
Got to take a ride down to the pond today. It's like driving through soup.
   / Kubota RTV 1100
Has anyone bought and installed the coast valve in the 1100? If so where did you buy it and how hard is it to install?
   / Kubota RTV 1100 #105
Over 2 years in mine. Wouldn't have an RTV without one. Took far less than 1/2 an hour to install.
   / Kubota RTV 1100 #106
I bought a coast valve for $139 on eBay. It takes about ten minutes to Install.
I decided to go back to the original valve after about 3 hours using it. My wife felt more comfortable driving the unit as it came from the factory, and since the 1100 is primarily her machine, there was no argument from me. I have the 1140 for me to play with. If you're interested in the coast valve, maybe I can save you some good money!
   / Kubota RTV 1100
Why didn't you install it in your 1140? What would you want for it? You can e-mail me at angussprings@zoominternet.net. I found the ones on ebay for $139 and another for $89. They look the same but ones is a copy of the other.
   / Kubota RTV 1100
New sound on the rear and a beacon.
   / Kubota RTV 1100
Did you install the beacon yourself and are there wires already up there to connect it?
David Kb7uns
I did install it myself. Not sure if there are wires up there. I pulled a new one when I pulled the speaker wires. Made the bracket with a little curve so that it would stay below the roof line so that when running through the woods it wouldn't get torn off by branches. The speakers are outdoor Bose that sound great and don't get in the way of the dump bed.
John Deere 4420 Combine (RUNS) (A50774)
John Deere 4420...
Genie GTH1056 (A50120)
Pneumatic Air Breaker Hammer with Hose (A50322)
Pneumatic Air...
2016 Ford Fusion SE AWD Sedan (A50324)
2016 Ford Fusion...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2009 Champion C80 B Motor Grader (A50322)
2009 Champion C80...
