Do HSTs roll when on slight incline and no pedal / brake
   / Do HSTs roll when on slight incline and no pedal / brake #1
rarvesen
Member
Central Texas (Texas Hill Country)
This might be a silly question, I'm a novice. I was told that the HST tractors will not roll when you take your foot off the pedal (you hardly ever need to use the brake). We have a new L3200 HST, and it rolls when on a slight incline and we do need to use the brake.
Does your HST tractor roll when on a slight incline when you take your foot off the pedal? Do you find that you do need to use the brake?
   / Do HSTs roll when on slight incline and no pedal / brake #2
Mine rolls a slight bit. It's less than if it was in neutral though. I think mine rolls forward but not backward. It could be a slight adjustment of the pedal could fix it but it's not enough for me to deal with.
   / Do HSTs roll when on slight incline and no pedal / brake #3
with mine, it will roll if the hst is not perfectly centered. On a flat surface, it doesn't roll, but on a incline, it rolls. The reason is the forward and reverse is on the same rocker and even if it properly greased, it tends to stick a little out of neutral so it rolls. When I see mine rolling, i just slap the hst pedal the opposite direction and it stops. I always try to use parking brake on a incline, but the eye can be deceiving what is an incline whats looks flat.
So if I were you, it doesnt matter if you have a geared tractor or HST, use the parking brake.
   / Do HSTs roll when on slight incline and no pedal / brake #4
Mine creeps very slowly downhill once the transmission is warmed up. Creeps faster in higher ranges. Not like neutral though, it will runaway well, like its in neutral. As a note, on the Kubota HST's, pushing the clutch in on an hst on a hill doesn't cause a runaway either.
   / Do HSTs roll when on slight incline and no pedal / brake #5
YES you need to use the brake when parking.
Thanks for the info everyone. I know you should always put the parking brake on when on an incline, but I want to make sure something is not wrong with the tractor, or needs adjusting.
Various people from different dealers said the tractor will not roll when on a hill, and you will never use the brakes since the tractor stops when the foot pedal is not pressed. Our tractor rolls on a much less steep incline than at the dealers. I don't mind if this is normal, but want to make sure there is not a problem or an adjustment required.
I'm going to ask the dealer, but it's helpful to also ask other owners.
   / Do HSTs roll when on slight incline and no pedal / brake #7
Yes it will roll if parked on an incline. And if you set the parking brake, unless you make it a habit of hitting your brakes every time before you get ready to move the tractor, you will forget and drive off with the parking brake on (not that I would have first hand knowledge of that). So I usually drop the FEL down. Unless you are on a severe slope, that will hold it.
   / Do HSTs roll when on slight incline and no pedal / brake #8
My land has pretty good inclines so like the others I put my FEL down and also my 3-pt attachment down.
   / Do HSTs roll when on slight incline and no pedal / brake #9
I have a L4400HST and I rarely use the brakes except when I park it. If I am in low range it will barely creep with the direction of the slope. If I am in a higher range the creep is a little more noticeable. If I get off of the machine on a slope I set the brakes even if the engine is not running. You may need to adjust your pedal a bit to center it.
   / Do HSTs roll when on slight incline and no pedal / brake #10
Howdy neighbor!
Those various people are just plain wrong. It is true you can use the tractor on flat ground without using the brakes much, but they WILL roll on a hill. I was backhoeing today on slight slopes and the tractor crept both ways (fore and aft) until I could drop the bucket.
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55301)
NEW HOLLAND 706 30...
2018 WACKER NEUSON RTSC3 ROLLER (A53426)
2018 WACKER NEUSON...
2016 Ford F-550 Shuttle Bus (A55788)
2016 Ford F-550...
378902 (A54865)
378902 (A54865)
2009 PARKER 25 T/A GOOSENECK TRAILER (A52472)
2009 PARKER 25 T/A...
RV Hitch (A50121)
RV Hitch (A50121)
