Power landscape rake - Woods and Harley the same?
   / Power landscape rake - Woods and Harley the same? #1
SnowNB
New-Brunswick, Canada
Kioti ck30hst
A dealer tells me the woods is made by harley and are the same, just different color?
Anyone has one or the other and how well do they really work?
A little expensive but would be worth it if it really saves a lot of hours for preparing new lawns.
   / Power landscape rake - Woods and Harley the same? #2
Your dealer is 100% correct, I have the Woods 72" model and the results are incredible after you learn how to use it. They are quite expensive but worthwhile if you have the need.
Matt
   / Power landscape rake - Woods and Harley the same? #3
Matt
Good timing for this post. This showed up at my place today! Wanna share any of those tips?
   / Power landscape rake - Woods and Harley the same? #4
Sure, I could try to explain them to you but there's a pretty good 4 part video on youtube detailing it. Here's the link to part
1:YouTube - Woods Equipment - PowerRake Part 1 of 4
It depends alot on your soil conditions, the final grade takes the most patients and practice. Make sure if it sits for awhile to follow the procedure for freeing it up. You can download the manual from the Woods site.
   / Power landscape rake - Woods and Harley the same? #5
I had already watched those videos about 5 or 6 times and found them great. I was hoping for a more real world look at tips or tricks. Hard to explain but there is always something you find with any new piece of equipment that you should or shouldn't do.
The rake actually came with a manual mounted on a tube on the implement. I have never seen that before. Then again, most everything I have bought is fairly dated.
   / Power landscape rake - Woods and Harley the same? #6
Ok, let me know how what your going to use the rake for and I'll provide any relevant input I have. I've used my both at my home for a new lawn and commercially in my area. I of course didn't want to learn how to use it on my customers dime. My yard had alot of rocks and different soil composition, so it was a good testing spot. I did have a recent experiance that may be helpful. I was hired to rake a 2 acre lot that was seasonally wet and had boulders poking through the surface. I looked at the job late fall and returned in the spring. Of course it was far to wet with standing puddles. When I returned to look a few weeks later the area was dry and the owner had used his mower to keep it short. I returned a few weeks later to begin the work and the grass was 18" to 24". Not having a mower I decided to give it a try. My thinking was that the rake would shred the grass anyways. Well it ended up be a huge hassle and I ended up boxblading and then raking to get desired results. The other tip is to give yourself plenty of time. Ground speed directly affects the end results. Most of the video's show the operators moving along at a decent pace. If you move at those speed you'll end up doing it over and over again. The other pointer is in regards to maintenance. I always keep extra bolts and nuts(with matching wrench/socket) while I'm raking. With all the vibrations the rake see's fasteners seem to loosen very fast. I've tried nyloks and loktite with mixed results.
Matt
   / Power landscape rake - Woods and Harley the same? #7
For the first rough run over it is often worth disconnecting the top link entirely, especially if you are doing "contoured" areas.
Then just use the 3pt lever to (more or less) follow - obviously you have to "read ahead" a bit on where the humps and dips are, where your tractor wheels are, etc.
   / Power landscape rake - Woods and Harley the same? #8
Matt
I will be using the power rake commercially. Basically I have been doing installs of lawns using a rototiller, drag & rake for the last 4 years and wanted to get a bit more serious. Our soil is rock free and I have an acre or so of my own to practice on. So when the weather warms up a bit more I will be out there getting a feel for it. Do you have the hydraulic angle and adjustable rollback barrier?
Thanks for the maintenance tips, I will definitely keep an eye on the nuts and bolts loosening.
   / Power landscape rake - Woods and Harley the same? #9
I will give this a try hopefully in a few weeks.
   / Power landscape rake - Woods and Harley the same? #10
His rake has a floating link connection. And yes on both the hydro angle and barrier, I usually set the barrier high on the first pass incase I unearth something I wasn't expecting. I also remove the side barriers for my intial passes unless there's signifigant grading to do.
Matt
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2018 HINO 338 KNUCKLE BOOM TRUCK (A51406)
2018 HINO 338...
1983 Case 580D (A47477)
1983 Case 580D...
2007 Capacity TJ7000 (A53314)
2007 Capacity...
UNUSED 70PCS White Metal Roof Panels (A53117)
UNUSED 70PCS White...
2019 GENERAC MLT6SK-HERC LIGHT PLANT / GENERATOR (A52706)
2019 GENERAC...
