At Home In The Woods
   / At Home In The Woods #2,841
Did you ever get the moisture meter for the wood flooring that was discussed, oh .. 50 some-odd pages ago? You can use it on firewood too. Somewhere in the 15-25% zipcode is decent for firewood. And when you get the brush-off "your wood is too wet" you can say for sure if it is or not. Plus if you buy wood, you can test it before they dump it to see if you are getting dry wood or not for real.
And if you need to cut into the drywall to fix this because the installation manual was not correct, then I think you should hassle the manufacturer to pay for the repairs. Not that they probably will, but it might feel good to stick it to them after the brush off they gave you... :) I realize a lot of the problems tech support folks see are of the common dumb mistakes, but I get real tired of hearing "Is it plugged in? Is it turned on? Did you try rebooting?" when I'm well past that point already....
dcyrilc said:
The property sold OK though?
Yes, our 61 acre property sold and is final. It took the seller about 2 weeks or less to close. He paid cash.
Obed
My wife measured the firewood we were burning onsite and it ranged from 18 to 26 percent. Sounds like it was dry enough. We didn't know what was good. We haven't measured the new wood but that's a good suggestion.
Obed
   / At Home In The Woods #2,844
So we are all hoping 1 little screw removed and your home will be all cozy and warm.:)
I remember having to cut into the new sheetrock on my new home weeks after moving in. Seems I was watering my grass outside and noticed the water seemed really hot.....:mad:
   / At Home In The Woods #2,845
I can relate. We bought a new fridge a few months back. It has a built in ice maker and filtered cold water. At least it would have if I had plumbed it into the cold water line in the first place.:ashamed: It works much better now that it's running on cold water.
   / At Home In The Woods #2,846
When you bring wood inside- watch out for carpenter ants and the holes in the wood they live in- They really can do a job eating framing wood inside the walls.
   / At Home In The Woods #2,847
I second this...
someone awhile back had some special trick to get rid of them in the wood pile..
But I don't remember what it is...
   / At Home In The Woods #2,849
Wednesday evening, WBWI and I talked on the phone. He has a Quadrafire 7100 fireplace like we have. I described our issues and tried to compare what I was seeing to what he sees with his fireplace. I was attempting to determine whether or not I was imagining our burning issues or whether they were real. Talking to WBWI helped. He said that his fireplace will burn just as big with the glass doors shut as with them open as long as he has the air control all the way open. He said that he did not have seasoned wood during the first year after his fireplace was installed but that he does not remember the fireplace acting any differently with the unseasoned wood as with the seasoned wood had used in subsequent years. WBWI was very helpful. He even went onto the Quadrafire page on Facebook and posed a question to the company for me. Thanks WBWI!
The questions concerning the fireplace started discouraging my wife. We literally designed the house around the fireplace, the fireplace being the central feature of the house. We placed the fireplace at an interior wall for heating efficiency. My wife did tons of research picking this fireplace. So to be questioning whether or not the fireplace was working correctly started weighing on her. It did not help that the fireplace tech had never worked on the model we have.
This week the fireplace tech called Quadrafire and relayed our questions. We could not call Quadrafire directly ourselves, The manufacturer gave the standard response - "Your wood is too wet. The chimney may be positioned such that it doesn't draft well. etc. etc." The manufacturer did not provide any resolution options other than for us to use different wood or rebuild our house.
I decided to get involved and called the local fireplace company who installed the unit and who was consulted in every piece of the design (fireplace location, location of ducts, heat zones, etc.). I ended up talking to a couple people at the local store, one of which was the local technician. They made some calls and talked to a service manager in Charlotte. The fireplace store is a national chain. The Charlotte service manager said that he had a customer with our exact same symptoms. He said that our fireplace ships with a screw that prevents the outside combusion air damper from being damaged during shipping. This screw must be removed to allow correct operation of the combustion air damper. The fireplace's installation manual says nothing about this screw. The tech who installed our fireplace is sure he did not remove such a screw. The Charlotte service manager said he is 99% sure that is our problem.
So the new fireplace tech we've been talking to and the store's district manager are coming out Monday to remove the screw. Unfortunately, we will have to cut through sheetrock in the master bath to be able to get to the fireplace. However, if this fixes the problem, we won't mind at all cutting the sheetrock. The fireplace people have been very helpful so far and did try real hard to help us. They could have easily just dismissed our case like the manufacture and said it was a problem with the wood, our education, etc.
To be sure, we had some "dry" firewood delivered to the house yesterday. Supposedly, the wood was cut over 6 months ago and has been stored under a tarp. The wood is Ash. I'm not totally convinced the wood is that old but I've heard that Ash burns real well, even when it is freshly cut.
Ash is a good burning wood. I consider seasoned as 9 to 12 months. Last week we finished our cutting and stacking for next year. We have mostly Oak with some Hickory. Ash may season a little quicker. The size of the pieces makes a big difference. Anything larger than 4" diameter I split or it will take longer to dry. I stack my wood off the ground so air can get under it and up through it. I cover only the top. Do not completely encase as it won't be able to dry as well. We have 4 stacks that are about 15' long and 5' high cut 18 t0 20 inches long. I figure it comes out to approximately 4.5 to 5 cords.
   / At Home In The Woods #2,850
I second this...
Sometimes if I see bugs on the wood which is usually on the bottom most wood of pile, I dont take it right away. I just tip it upright against the wood pile and leave there for a few days. Bugs don't like the open air and light so they scatter on thier own. I just keep taking the wood from top/middle of pile. When I need more wood and its nice outside, I'll make a armful of "buggy wood" trip. I just throw it right on the fire, no delay. 98 % of time there are no bugs on the wood, and if there is any, I feel safer that its in the stove right away.
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
2006 Dodge Ram Pickup (A56858)
2006 Dodge Ram...
(APPROX. 640BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 640BF)...
10 X6 MANIFOLD (A58214)
10 X6 MANIFOLD...
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A55852)
2023 Fat Truck...
30in Forks and Frame Mini Skid Steer Attachment (A56857)
30in Forks and...
