Leased vs owned tanks - how to tell?
   / Leased vs owned tanks - how to tell? #11
All I have is the 55-27" tanks. I typically go to the welding supply company but if they are closed, I go to TSC. Both places are tank exchange with no questions asked.
   / Leased vs owned tanks - how to tell? #12
Years ago I bought tanks from where I was leasing. They went out of business and I went 10 years. Went to refill- couldn't until they found I once had an account at another welding supply they had bought out. They found me in the old records. I guess the moral is- keep active and refill often!
All good info...but does anyone have any pics? Enquiring minds...
I might have time Mon to stop into the LWS, so I can see what they say. It's only curiosity at this point as I have no room for tanks right now...
   / Leased vs owned tanks - how to tell? #14
In my area. They will only lease tanks. It was like a 99 yr lease. Forget the cost. 99 yr lease:confused::confused2:. I would say I bought them ,but paper work states lease
   / Leased vs owned tanks - how to tell? #15
if you look at the ring just below the valve you can see that the top picture has a smooth raised ring. the lower picture has a name stamped into it. this is what people are talking about when they describe the top of the tank. the smooth one is an owned tank and the named tank is leased.
i acquired the smooth tank as part of a private sale deal when i bought a welder. it is a 60cf tank, and i went to three welding supply stores in a 30 mile radius and every one had no issue setting me up with a customer owned bottle swap deal. each one pretty much said that tanks that size are generally customer owned, and they have no issues with filling them.
once you step up in sizes to the +/-125cf and then +/-250cf (i am not sure of the technical designations for these) you will usually be dealing with a leased tank. individuals can purchase these but unless you go back to the dealer you got it from, they will probably hassle you for a shred of proof that you own the tank.
from what i see for replies whenever lease/own topics come up, there is a big difference regionally on leasing. of the three dealers i know here one will do one year leases only, one will do 1 or 3, and the other will do 1 or 5. some will do longer leases, but only for volume businesses with 10+ bottles. also, some talk about sending their tanks away to have them filled, and to me this seems tedious because of the down time. none of the three dealers here do that. all are on an exchange bases even for customer owned tanks. you never get the same tank back, so discuss with them ahead of time how you prove that the tanks are yours if you take them to another dealer.
   / Leased vs owned tanks - how to tell? #16
All my are customer owned I have about 6 ox (LOG) 8(Large) aragon 2 Large acetylene they all have clean neck rings I travel Az.,Calf.,Nm., and Tex. I have had trouble in austin had to have my supplier cal them tell them they were mine and they chewed them out because they had clean neck rings and that is only time I have problens. watch murpey law strick and will have trouble now.:thumbsup:
Lostcause - THANK YOU! That is exactly what I was looking for. The Oxy tank that I saw had "Union Carbide" stamped where yours says "Regulator Service" (or whatever it fully reads). This is what I suspected it would look like, but was never sure without someone showing me just what you did!
You need a reward for that. How about a dancing banana? It's the best I can do...:) Thanks "a bunch" :)
attachment.php
   / Leased vs owned tanks - how to tell? #18
Just because it has or does not have a company name on the ring isn't a sure thing the bottle is a lease or a customer owned tank. The only time I am sure it always applies is when it has the name" Customer owned" stamped into the ring. (ie raised letters). The size plus the ring and the prefix of the serial number of the bottle are all factors.
I maybe incorrect, but I am pretty sure all pressures for the same gases are the same, so if your buying O2 in 2 different size bottles, and getting different pressures then somebody MIGHT be transfilling them and shorting you on xx number of cubic feet of gas,which is how bottled gas is typically sold. Different gases (high pressure) fill the same size tank at different pressures to reach the correct cubic footage for a bottle.
Clear as mud!!!
David from jax
   / Leased vs owned tanks - how to tell? #19
Clear as mud!!!
David from jax
The fill pressure will be stamped right on the neck of the bottle.
My 200 cubic foot oxygen is 1800#
I have others in the shop that are 2015#
For work, I was able to negotiate no charge rentals as long as I order an average of 40 cylinders per month... which has not been a problem.
The local Airco Supplier was very generous at one time... I had brought in some Airco Cylinders that were left behind in an old warehouse... the Supplier offered me 5 year free rental just for bringing them in... I declined because I already have my customer owned cylinders.
http://www.airgas.com/content/details.aspx?id=7000000000234
http://www.airgas.com/content/details.aspx?id=7000000000243
   / Leased vs owned tanks - how to tell? #20
One of the other welding supply companies had an employee selling gas to small shops and pocketing the cash. He was found and fired. I came across one of those shops that had closed, that had about 200 of those empty bottles. Called the owner of the supply store to see if a finders fee could be negotiated and he wouldn't even give me one pair of welding gloves for my trouble. Owner of the building asked me what to do with them, so I handed him a business card of a scrap guy that would give him a few pennies of what the stuff brought at the scrapyard once he torched the tops off and separated the valves. The welding supply store owner asked me about them six months later and I told him they were gone. He was upset, because he thought he could locate them by doing driveby's of all the shops his crooked employee had contact with. I guess he found out his employee had more customers than he was writing tickets on.
Shame, but it put food on somebodies table, to clear out that shop. Just not mine...
David from jax
UNUSED FUTURE POLYTHYLENE PROTECTION PAD (12 PCS) (A57193)
UNUSED FUTURE...
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
Mohawk 12,000lb Two-Post Electric Auto Lift (A54811)
Mohawk 12,000lb...
2018 XCMG CV83PD (A53317)
2018 XCMG CV83PD...
UNUSED FUTURE MINI EXCAVATOR RIPPER (A57193)
UNUSED FUTURE MINI...
2020 Toro Pro Sweep Vacuum (A55758)
2020 Toro Pro...
