For those of you who have changed your front axle oil...
   / For those of you who have changed your front axle oil... #1
bandit67
Lake Hartwell, SC
2012 B3000 HSDCC 2020 Z251 Zero Turn
Did my 300 hour service today, and changed the front axle oil for the first time per the Operator's Manual.
I was a little surprised at how much "microscopic" metal flecks were in the oil, though probably not that surprising given the 300 hours of use. I probably should have done it at 50 hours, but decided back then to go with what Kubota recommended.
So, for those of you who have done the axle change, did you also find plenty of "metallic sparkle" ? I collected a sample, if it turns out that it seems as if my situation is uncommon, so that I can then send it off for analysis.
   / For those of you who have changed your front axle oil... #2
Bandit,
What did you use for oil....??...what does Kubota use for new equipment....??
   / For those of you who have changed your front axle oil... #3
Kubota fills with sudt. At the time of purchase, my dealer stressed the need to dump it virtually immediately and fill with gear lube. I listened to him. He based that recommendation on their experience. FWIW.
Although, given our brutal winters, I did re-fill with synthetic 75w-90. Same price as dino 80w-90. I am sure there will be some metallic wear in that axle. I don't see how it is avoidable completely.
   / For those of you who have changed your front axle oil... #4
I also had little "sparkles" in the sudt oil when I changed it in my 3940. Went back with gear lube. Not concerned about the metal flakes. All part of the break-in.
   / For those of you who have changed your front axle oil... #5
Nice avatar Happyman..!!
   / For those of you who have changed your front axle oil... #6
I have done all of mine at 50 hrs and was surprised each time how dirty it was for so few hours. 50 hrs is the max time I would run these difs before the first change.:thumbsup:
   / For those of you who have changed your front axle oil... #8
I got a nice 9 pt/196# this year.......sorry to get off subject......:ashamed:
   / For those of you who have changed your front axle oil... #9
Ooooo, I see Kubota recommends changing it at 400 hrs in my operators manual......I'll have to check with my guy to see if he changed it at 50 or just checked the level......
I'll be on this one.......don't like the silver stuff in my oil either.....:confused2:
Quite the extremes between the SDUT and the 80/90wt.........
   / For those of you who have changed your front axle oil... #10
The weight of the oil isn't whats important, it's the lubricity. I wouldn't worry about running either, I personal run 80w-90 since its cheaper and I have it in bulk in the shop here.
Well, I guess I'll keep an eye on it this next go-around.
Not sure what was in it from the factory back in '08, but there didn't appear to be significant breakdown in the oil itself, so lubrication was probably fine. Oil viscosity seemed more like UDT or SUDT than the gear oil. I refilled it with SUDT2, which is synthetic, though I'm not sure if it's a synthetic blend or full synthetic.
I may change the intervals to 150 hours on the axle just for some added insurance if it is determined that the SUDT2 is not a full synthetic.
I'm not all that concerned with what I found, but I have a better idea of the wear going on in there now. If I had found anything larger, I'd be tearing into the front end to check it out, but I'm pretty confident, based on the consistency in the miniscule particle size, it's normal.
As a side note, I ran Shaeffer's synthetic blend in the tranny/hydro from 50-300 hours, and it was perfectly clear and looked brand new. This time around, it was easier to get the SUDT2, plus I was getting tired of the particular odor of the Schaeffer's when it got real hot, so thought I'd try the new Kubota synthetic.
   / For those of you who have changed your front axle oil... #12
I did my B3030 at 50 hours and re-filled with with SUDT, I was surprised how dirty the fluid was, on the last few drips out while I was draining it I got a really fine shiny glimmer of metal particles but nothing that got me concerned
   / For those of you who have changed your front axle oil... #13
My tractor had about 2000 hours on it when I got it. I changed my axle oil after I used it for about 300 hours - it looked like there might've been UDT in there, but I don't know for sure - I put in 75W-90 dino gear oil. I changed it again after 200 hours (1/2 gallon low at that point due to bezel seal leak) and filled with 85W-140 gear oil (like molasses - good for a bezel seal leak). I don't remember either of the dumped oils being particularly dirty and definitely don't remember there being any metallics in it.
I wouldn't worry about it too much if it was the first change.
JayC
   / For those of you who have changed your front axle oil... #14
On mine the metallic specs where a bearing cage that got eaten up. Replaced the seals and bearings on that side.
   / For those of you who have changed your front axle oil... #15
Really? SUDT and not UDT or some generic hyd oil? Is that what the dealer
says? If SUDT, that is quite surprising as that cold-climate stuff is
expensive, and I think those units are assembled in GA.
Anyway, going to a gear lube ASAP is what I would do, too. There is no
filtration in an axle.
   / For those of you who have changed your front axle oil... #16
Yes, it is easier to just fill them all with sudt, or so it is reported. One gun fills them all. Done. Just reporting, not verifying anything. Actually, sudt and sudt-2 is pretty great stuff, and SUDT (in spite of the stupid snow flakes on the bottle) is NOT just for cold climates, but I digress.
In any case, udt or sudt, made no difference to me. It is an axle and axle gear lube went into mine. End of story.
Same thing with my RFM gear box. Sucked out whatever came in there and re-filled with synthetic 75w-90. Only took 14 oz, so good peace of mind.
   / For those of you who have changed your front axle oil... #17
Did my 300 hour service today and used Premium UDT in the transmission, Wal-Mart tractor trans-hydraulic oil (says on the jug it meets Kubota UDT spec.) in the front axle, and Rotella T 15W40 in the engine.
   / For those of you who have changed your front axle oil... #18
Extreme pressure on the gears is going to hone the driven parts. Metal flake of tiny chips will be there even if you have no failures. Differentials generate a tremendous amout of heat when operating.
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A55853)
2003 International...
2016 Ram 4500 Chassis Ambulance (A59230)
2016 Ram 4500...
2018 Claas Volto 900 (A53317)
2018 Claas Volto...
2011 Ram 1500 Pickup Truck (A59230)
2011 Ram 1500...
(4) UNUSED FORERUNNER 10-16.5 SKID STEER TIRES (A60430)
(4) UNUSED...
2474 (A60432)
2474 (A60432)
