#4 Gravel is a LOT easier..
   / #4 Gravel is a LOT easier.. #1
Haywire
Central Kentucky
Tractorless :(
..to scoop with the FEL than dirt but it's heavy... I was really glad that my tires were loaded and my box blade was back there. :eek: Drop that bucket a few inches, stop it a little too abruptly and you can feel the back of the tractor try to lift.
Ian
   / #4 Gravel is a LOT easier.. #2
One time I stepped off the tractor with a bucket full of wet manure and the loss of my weight in the seat was enough to lift the rear wheels. Fortunately the bucket was only up a few inches so I just jumped back on and the rear wheels came down. Before we do all the fat-***** jokes, I only weigh 160#.
   / #4 Gravel is a LOT easier.. #3
I think both you guys need ballast boxes!
   / #4 Gravel is a LOT easier.. #6
I have one, it's sitting out in the field holding down the weeds.
Well ... it could be sitting on the back of the tractor holding down the wheels.:p
larry
1999 Case IH 4300 Field Cultivator (A59814)
1999 Case IH 4300...
Case Axial-Flow Combine Wheels NO RESERVE (A56438)
Case Axial-Flow...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2019 FREIGHTLINER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
WEILER S350 SKIDDER (A60429)
WEILER S350...
