SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 10,379
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
pins, bolts makes absolutely no difference if the "shear strength" of the pin meets or exceed that of bolt in question. Why is it that many new folding ROPS rely on hitch pins?
JC,
If it's designed for pins, fine. If it's designed to be clamped with bolts, that's different. To meet certification, the ROPS needs to be maintained as originally designed.
I only throw this out there because in the event of a failure, liability falls upon the individual who made the modifications.
Well, heres some fact. As was intimated back in Post#20 ... Shear relies on joint surfaces restrained to position very close to each other. If it spreads under force the shear is greatly affected because the pins/bolts are bent instead or additional to shear. A bolt clamped joint will not spread. The safe side is to use Gr5 bolts with shank crossing the full shear zone. Tighten them to a few foot lbs - not a hundred - to clamp while not crushing the uprights.That is true enough. Let's just say the bolt is class 2 and one replaces with class 5 equivalent pin. In the case of law suit obviously manufacture blames owner modification, case closed even if the replacement exceed original specs. We're simply giving opinion to the OP based our personal experience or knowledge. Op is the one that will sort it out and would make his decision as an adult.
JC,
larry
