Hydraulic Flow & Fence Post Auger Possibility
   / Hydraulic Flow & Fence Post Auger Possibility #11
I've dug a couple hundred with my little 1610d and 3pt. TSC phd.the bit works good in my clay.as said sometimes will spin in so I invested in a large aluminum pipe wrench.The only conditions it won't work in is Rocks.then it's all hand work with the rockbar. russ
I haven't tried the add water trick, but I think it would probably work. And if it isn't an auger that is rented this would allow the time needed to add water and come back later to continue.
As for the hundreds of posts, I haven't drawn up a map yet, but I'm going to fence the entire 48 acres and then divide them into several paddocks. I'll be using a lot of T posts also. I was planning on putting a heavy wood post every 50-75 feet or so in straight runs to keep it from leaning. I've seen old t post fences completely bent over and nearly touching the ground at the top. Granted those fences had years of neglect, but reason enough to encourage me to kick it up a notch.
I guess I'll keep reading about the hydraulic piece of this idea. If I get really attached to the idea the only thing holding it back is flowrate. I know this type of auger works well if you have the flowrate to spin it. Glancing at the specs of a couple of these mini skid steers they have 25-35HP engines and have hydraulic flows of 11.5 -14 GPM @ 2600PSI. I don't think this puts it out of reach for a compact tractor, but may encourage that unless the unit was intended to have surpluss flow rate it would likely need a bigger pump installed.
   / Hydraulic Flow & Fence Post Auger Possibility #13
A good 3 pt auger is your best bet ... It has been said, don't let it auger in as it wants .... control the depth so it does not screw itself in tight... also stated good point and sharp.
With the skid steer type on a skid steer you can see the point to set it where you want ... as well with a 3 pt ... now on a loader in front of the tractor ... well I think that may be difficult to judge.
   / Hydraulic Flow & Fence Post Auger Possibility #14
Also ... we have some bad clay here. At times we cant drive a t-post. But here are some pictures of 10" holes I just dug a couple days ago ... and its been dry.
   / Hydraulic Flow & Fence Post Auger Possibility #15
The ym2000 only has about 4 or 5 gallons per minute flow rate.
   / Hydraulic Flow & Fence Post Auger Possibility #16
I have a Yanmar 1610D and a howse PHD. As others have said run it a little then pop it up to remove the dirt and so it doesn't screw itself in and get stuck. As to the HST and positioning the tractor my Yanmar with the powershift works fine because once the range gear is selected you can go from forward to reverse to position for the hole without touching the clutch. Mine also has a creep gear so once I get the PHD where I want it I shift to creep and if I need to move to keep the hole straight I just pop it in forward while the PHD is drilling and it moves along nice and slow to keep the hole straight. I have really hard gray clay on my property and have never had a problem drilling a hole except for one time but you can't auger through a buried stump. I have never broken the shear pin it is still the original.
What's the biggest diameter auger bit you have used withthe 1610D? That's 19.5 HP correct? Wondering about the torque. Being a diesel it should be an advantage.
   / Hydraulic Flow & Fence Post Auger Possibility #18
I have a 6" auger as I mainly use it for fence posts. As of yet I have never seen enough of a need for a larger auger. They only time I have needed a larger hole (for planting trees or shrubbery) I have just drilled more than one hole and used a shovel to dig it out and combine them to make a large enough hole.
   / Hydraulic Flow & Fence Post Auger Possibility #19
I use a 9" on my 1610d,pto hp is 16hp,20hp engine. russ
   / Hydraulic Flow & Fence Post Auger Possibility #20
i use a 6 and 12" on my PTO drive PHD and my 1500 does it easily.
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
40ft High Cube Shipping Container (A51573)
40ft High Cube...
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
APPROX 500 GALLON FUEL TANK (A51248)
APPROX 500 GALLON...
2023 Canam Defender Lonestar (A51572)
2023 Canam...
