Backhoe Zerks for KB 2485~ size?....
Status
Not open for further replies.
   / Zerks for KB 2485~ size?.... #1
Coyote machine
Super Member
Southern VT
22 SANY SY 50U, '10 Kioti DK 40se/hst KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 BB, Woods QA forks, MIE Hydraulic bhoe thumb & ripper tooth, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Brush Mower. Diamondplate aluminum canopy
Broke off a Zerk and then lost it after removing the broken piece from the hoe's stabilizer arm piston 'wrist pin'.
Are they a standard size and if so what is it please?
Thanks in advance!:thumbsup:
   / Zerks for KB 2485~ size?.... #2
In the Backhoe I had on my Kioti they were just standard Zerks. That was all I had and they just screwed right in okay.
The Fox
   / Zerks for KB 2485~ size?.... #3
Yes, I searched all over for Metric Zerks because someone said they were metric, but when I broke one on the loader pins, I found that they were standard NPT.
Thanks guys- I'll check out what TSC has in stock and pick up a bunch for use in the future too.:cool:
   / Zerks for KB 2485~ size?.... #5
Good luck and let us know what size works. I've had to replace a couple on my 2485 and have yet, after trying several sizes (per manual, Kioti dealer, and parts store measurement), to find one that will match exactly. Very frustrating.
   / Zerks for KB 2485~ size?.... #6
1/8 th Any local auto store sells them
rimshot
rimshot
I'm curious- are you certain of them being 1/8th inch? I ask because I removed one from my Bhoe's stabilizer arm, and it had a 10mm wrench 'nut' size on it but the 10mm zerks from TSC seem to have a somewhat different thread on them- possibly tapered? - or as you say it may very well be 1/8th inch... I'm just wanting to verify, not questioning your accuracy:)
Thx,
CM
   / Zerks for KB 2485~ size?.... #8
CM
yes sir I am sure. I changed a couple grease zerks on my KB2465 and went through the same thing as you with the Metric variety. But just to be certain I double checked the book (owner's manual. Look for the page showing the breakdown on the boom. They show a grease zerk on that page and it is marked P.T. 1/8th.
rimshot
rimshot
Thanks for your confirmation!:thumbsup:
Got around to finding a couple of 1/8" zerks and they do NOT fit my backhoe. I took out the old broken piece and another good one and switched positions to keep the old Kioti factory supplied one in the position where I broke off the original Zerk. Tried for some time to screw in the 1/8" replacement and it would not go. I tried wrenching it carefully to get it started and it wanted to tear out the threads in the hole.
Tried the old good factory one and had to chase the threads. Called my dealer to confirm exactly what is the right one and he said they are definitely metric but he too has had problems because some metric ones don't seem to work either!?
I'll probably get some from him next time I get over to his shop.
Thought I'd bring people up to date on this topic- though I still don't have any clear answers as to what exactly to buy as to pitch and thread size.:confused2:
Status
JOHN DEERE 853M TRACKED FELLER BUNCHER (A52707)
JOHN DEERE 853M...
SET OF PEMBERTON FORKS (A52707)
SET OF PEMBERTON...
2025 Swict 78in Bucket Skid Steer Attachment (A53421)
2025 Swict 78in...
2009 Kubota RTV-1140 4x4 Diesel Utility Cart (A55851)
2009 Kubota...
1607 (A57192)
1607 (A57192)
UNUSED FUTURE PG72 72" HYD PLATE GRABBER (A57193)
UNUSED FUTURE PG72...
