First Pics of 3520
   / First Pics of 3520 #11
Nice machine, you will find it very powerful. Much more power than the 3320 I used to own. the turbo engine of the 3520 has the 3320 beat in every way. well worth the extra $$$:thumbsup:
I opted for the 3320 because of fuel economy and no turbo. "Every way"? No, just more HP, they're both the same tractor. Yes, those are the small R4's, Deere has two R4 tires for that tractor, neither is 'correct'.
Nice unit, LHS!
I have a 2005 3520 with 500 hours on it that I bought used a couple months ago. It has been a great machine so far.
Question for you:
What is the tread thickness of the front and rear Galaxy tires on your tractor?
I have the same tires on mine, and I'm just wondering how much wear they have on them compared to new tires.
Thanks,
Spindifferent
I'll have to check on it and get back to you. From what I've read the R4's wear like iron.
LHS,
Very nice addition to your stable of tools, bet you will love this tractor.
Yes, I'm loving this tractor more all the time. Many thanks to you and all the others who posted kind remarks.
   / First Pics of 3520 #14
Small R4's is not a criticism it's an observation! Both tires are fine.
   / First Pics of 3520 #15
Where do I find the fuel economy ratings for the 3520 vs the 3320 ? My dealer told me that my new 3520 would be better on fuel. I though since 3530 was more hp it would work less to do the same as the small 3320, then save fuel ? Turbos are better right ? I mean they cost more so it should be better.
   / First Pics of 3520 #16
ROB, I just found the fuel ratings, yes the 3320 only uses 2.0 gal an hour and the 3530 uses 2.4 gal per hour . but the extra hp of the 3530 will get the job done faster than the smaller 3320 so the it would save fuel since the 3320 would still be working. Right? Since it has a turbo and it cost more to build
   / First Pics of 3520 #17
I have a 3520 but almost purchased a 3320. I think both are fine and really there isn't much difference between the two. I just happened to get my 3520 new for cheaper than a 3320 new (long story), but I doubt any of the tasks I do with my 3520 I couldn't do with the 3320. You will lose traction way before you run out of power, IMO.
   / First Pics of 3520 #18
Specs:
Product Specification for 3520 Compact Tractor (37 hp)
All the info is in the specs.
We've had lengthy discussions about turbo and non turbo. Basically it comes down to what you like. I like the non turbo (3320 engine is bigger that the 3520/3720) I'm not a big turbo fan they run hotter but the Deere's are pretty much bullet proof either way. I want to keep the fuel usage down low, most time my tractor runs at ~1600 rpms except when I'm blowing or bush hogging. 33 hp is enough for me (right now anyway) and it pulls all my implements. I like the two series for running around. They're nice little tractors but they won't do the work I need so I went to the 3320 with the 48 BH, I'm set, the 46 hoe just didn't do the heavy work I wanted it to. It's a nice hoe though.
Cost is a factor in some things but not so much in the engines. Cost gets you more hp with more complexity. Usually cost in tractors gets you bigger pumps, faster hydros, etc.
I would say at 16000 rpm both tractors get close to the same economy with the 3320 having the edge. Full out I'd say the 3320 does marginally better
Rob
   / First Pics of 3520 #19
Let's get back to the OP's new tractor...you guys can fight out the 3320/3520 specs in another thread or PMs.
That's a fine looking tractor, LHS Inc!!!
So, what's your Dad think of your "toy" tractor?
   / First Pics of 3520 #20
The only place a 3520 or 3720 will top a 3320 is with pto implements. My 3320 will run out of traction well before power and I've got loaded tires an a 448 on the rear. And as Rob stated the 3320 has the largest engine of the line. As for the R4's those are the smaller size but I believe the smaller units have more load capacity. To the OP you'll be super happy with your new toy. Congrats!!
Matt:D
2015 INTERNATIONAL 28 PASSENGER HANDICAP ACCESSIBLE SHUTTLE BUS (A52577)
2015 INTERNATIONAL...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
1993 Trail Boss Lowboy Trailer (A52384)
1993 Trail Boss...
2011 Ford F-350 Knapheide Service Truck (A51692)
2011 Ford F-350...
