5' KK behind Kubota L 3400
   / 5' KK behind Kubota L 3400 #1
praha
Chicago suburb
Kubota L3400 gear
Hi,
I just bought 5 feet wide KK. I hope my L3400 will be able to handle it without a problem. Anyone has an experience with it?
Thanks,
Joe
   / 5' KK behind Kubota L 3400 #2
I'm assuming you purchased a rotary cutter in which case you will have no problems at all behind a L3400.
   / 5' KK behind Kubota L 3400 #3
You've got the required PTO HP. At worst case (if the tractor's engine starts bogging), you may have to slow down.
Keep at eye on the temperature gage and keep the grills clean when brush cutting.
   / 5' KK behind Kubota L 3400 #4
I run a 5' king cutter on my l3400... no problem. Ditto what Roy said about keeping the radiator screen clean... it plugs up faster than you would think.
   / 5' KK behind Kubota L 3400 #5
Check your gearbox oil ! Also watch lift angles if running on hilly terrain.
You should'nt have any trouble w/that 5'.I run a BH 172 (6') behind my L3400.
Boone
Well, I just skipped the most important information. What a moron!
5' KK TILLER. Sorry for wasting your time guys.
Joe
   / 5' KK behind Kubota L 3400 #7
I have a 6' KK behind a 3400 (gear). Just make sure the slip clutch is adjusted properly.
   / 5' KK behind Kubota L 3400 #8
I am running a 5ft tiller on a L3240 and it does fine. It does bog a little in wet ground.. Other than that I have no problem.. Geee shouldnt run it in wet ground anyway! :D
AndyG
I also have a stick shift/gear 3400.
2025 GIYI VR66 66in Vibratory Roller Skid Steer Attachment (A55787)
2025 GIYI VR66...
2006 MAC TRAILER MANUFACTURING (A55788)
2006 MAC TRAILER...
2003 Ford F-550 Versalift VST236I 36ft Bucket Truck (A55788)
2003 Ford F-550...
BFH 1000 BALANCE FORCE HARMONICS TIRE BALANCER (A54757)
BFH 1000 BALANCE...
United 5' 3pt. Box Blade (A50775)
United 5' 3pt. Box...
Mini Excavator (A55787)
Mini Excavator...
