Diesel Standby Generators
   / Diesel Standby Generators #1
sparrowhawk
Maine
JD x749, LX277
Does anyone have one that they would recommend out there? I see several different offerings including ones with Perkins diesels in them. Optimally, I'm looking for a 15KVA but a 20KVA would work fine as well. Any suggestions?
I'm not a fan of propane or natural gas, so I want to stick with diesel. Thanks in advance.
   / Diesel Standby Generators #2
1*I'm not a fan of propane or natural gas, so I want to stick with diesel. Thanks in advance.
1*Here's why i prefer diesel /\ Unlimited Fuel Storage Capacity.
   / Diesel Standby Generators #4
Just make sure your wallet opens real wide, because they will cost a pretty penny.
   / Diesel Standby Generators #5
   / Diesel Standby Generators #6
Get liquid cooled unit, air cooled genny will be 2 pole which means 3600 rpm operation. A 4 pole turns 1800 rpm but requires 3-4 cylinder usually.
Norpro | A Whole Lot More Than A Diesel Generator Manufacturer
These are some real beauties here, I dreamed of one of theirs but just went with a pto gen instead since I already had 2 diesel power plants (tractors)
Good luck, JB.
   / Diesel Standby Generators #7
   / Diesel Standby Generators #8
Any reason why you would not go PTO driven? :confused2:
   / Diesel Standby Generators #9
I went pto for a few years. Heres why I sold it and went standby.
~Have to take implement off the tractor to hook up. We always loose power during thunderstorms and heavy snow, neither is fun to do in either situation.
~Tractor often was not handy to the house. Sometimes in another hayfield or at another location.
~I didn't mind running the tractor all night, did it numerous times for 24 hours or more, but it's overkill.
~During a storm it's nice to have the use of the tractor.
~When I was away, my wife couldn't unhook the implement on the tractor and rehook to the gen.
For some a PTO works great, for me it was a real hassle. The auto start does it's thing no matter where I am, no worries of the house freezing up or if my wife is ok when I'm dealing with a storm for the FD or with my business.
I would go PTO but I need something that is ready to go when my wifey needs it versus me hooking it up etc. I will probably get a PTO driven one as well because they are short money, portable and handy for other things.
Thanks for the maine references as well! I've lost my power 4 times in the last 10 days so enough is enough.!
Yep, I know diesel is a lot more expensive but they are also much more durable than the residential propane models from what I hear. I'm mid reconstruction so I'm having the electrician make provisions for a generator now.
I'll check out your recommendations and let you guys know which way I go. THANKS as always!
2021 Ford F-150 4x4 Crew Cab Pickup Truck (A48081)
2021 Ford F-150...
2019 Chevrolet Malibu LT Sedan (A48082)
2019 Chevrolet...
2005 Ford F-250 4x4 Ext. Cab Pickup Truck (A48081)
2005 Ford F-250...
UNUSED Clear Corrugated Polycarbonate Roof Panels (A50860)
UNUSED Clear...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
2005 Ford F-750 Crew Cab Heil 5 Yd Dump Truck (A48081)
2005 Ford F-750...
