MtnViewRanch
Elite Member, Advertiser
- Joined
- Mar 19, 2005
- Messages
- 10,647
- Tractor
- Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
How much does your 41hp tractor weigh? Weight of the tractor and the grader implement is a big factor on what you should get. How much do the Big Bee implements weigh? I have a 7 footer that weighs about 1400lbs and if I don't pay attention it can stop my 12,000lb tractor cold.
I happen to agree with you about a 6 footer. In general I would say that a 6 foot grader blade would be the best fit for your tractor. There are many other builders of these grader blades, you are not stuck with either a Dura grader or Big Bee grader blade.
Here are a few links to some other manufacturers of these type of grader implements.
Home | Road Boss Grader
GradeMaster Grader Blades
Land Pride Grading Scrapers
Whatever you do, do not get a blade that is too big for your tractor. All that you will do is end up fighting with it.
