MF 135 Hydraulics Shake When Lifting
   / MF 135 Hydraulics Shake When Lifting #1
nolarefugee
MF 135, Ford 4000
Hello all, first post...
1966 MF 135, when I raise the implement, it shakes / shudders. It goes up w/o any problem other than the shakes. Goes down smoothly.
Any idea what the cause / remedy could be?
Also, I noticed that if I leave it up with a load, say the bush hog, it will, very very slowly - go down. Is this normal? Are these two related?
   / MF 135 Hydraulics Shake When Lifting #2
My loader shakes a bit when I lift it if I haven't throttled up enough to get decent pressure from the pump. Does it make a difference on throttle position?
As for the downward drift either the cylinders are bypassing or the shuttle on the spool is. Also I have heard that at times the draft control(if you have it) can cause sag.
   / MF 135 Hydraulics Shake When Lifting #3
Welcome to TBN:D
Is the fluid foamy looking?
I will check on the throttle position. Don't remember off the top of my head.
I haven't looked at the fluid, but will check it out.
   / MF 135 Hydraulics Shake When Lifting #6
we have a david brown 996 and the loader was the same this was simply down to a slightly low oil level in the hydrolic system it was suprizing how much difrence it made
so id chek the oil for a start sounds simple but its the simplest of things wich cause the bigest problems
   / MF 135 Hydraulics Shake When Lifting #7
My MF 135 does the same thing. When I have my backhoe on, I pretend that its operating like a jack hammer :). My fuild is new, at the proper level and I cleaned the internal filter screen, no change. Since it does the same with my backhoe, I know its not the lift cylinder so its likely the pump. Now my draft control no longer functions and I have read a bit where there is some spring or something that likely fell off. Personally I just live with it (though I bought an external pump that I am going to run off the PTO for the backhoe this summer.
   / MF 135 Hydraulics Shake When Lifting #8
look at your filters that might be your problem ???
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
UNVERFERTH 18' FIELD CULTIVATOR (A52708)
UNVERFERTH 18'...
2025 SF60 60in Hydraulic Forks and Frame Skid Steer Attachment (A56857)
2025 SF60 60in...
JOHN DEERE 4020 TRACTOR (A52708)
JOHN DEERE 4020...
LOT: Assortment of Opened Oil, Coolant, Parts Wash, Hydraulic Oil (A59076)
LOT: Assortment of...
SET OF TRUCK FENDERS AND HARDWARE (A58374)
SET OF TRUCK...
