MF 135 Hydraulics Shake When Lifting
   / MF 135 Hydraulics Shake When Lifting #1
nolarefugee
MF 135, Ford 4000
Hello all, first post...
1966 MF 135, when I raise the implement, it shakes / shudders. It goes up w/o any problem other than the shakes. Goes down smoothly.
Any idea what the cause / remedy could be?
Also, I noticed that if I leave it up with a load, say the bush hog, it will, very very slowly - go down. Is this normal? Are these two related?
   / MF 135 Hydraulics Shake When Lifting #2
My loader shakes a bit when I lift it if I haven't throttled up enough to get decent pressure from the pump. Does it make a difference on throttle position?
As for the downward drift either the cylinders are bypassing or the shuttle on the spool is. Also I have heard that at times the draft control(if you have it) can cause sag.
   / MF 135 Hydraulics Shake When Lifting #3
Welcome to TBN:D
Is the fluid foamy looking?
I will check on the throttle position. Don't remember off the top of my head.
I haven't looked at the fluid, but will check it out.
   / MF 135 Hydraulics Shake When Lifting #6
we have a david brown 996 and the loader was the same this was simply down to a slightly low oil level in the hydrolic system it was suprizing how much difrence it made
so id chek the oil for a start sounds simple but its the simplest of things wich cause the bigest problems
   / MF 135 Hydraulics Shake When Lifting #7
My MF 135 does the same thing. When I have my backhoe on, I pretend that its operating like a jack hammer :). My fuild is new, at the proper level and I cleaned the internal filter screen, no change. Since it does the same with my backhoe, I know its not the lift cylinder so its likely the pump. Now my draft control no longer functions and I have read a bit where there is some spring or something that likely fell off. Personally I just live with it (though I bought an external pump that I am going to run off the PTO for the backhoe this summer.
   / MF 135 Hydraulics Shake When Lifting #8
look at your filters that might be your problem ???
INGERSOLL RAND G25 GENERATOR (A58214)
INGERSOLL RAND G25...
SCALES & PEA (A58374)
2019 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2019 Ford F-550...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2014 Sakai SV540T Pad Roller, Chassis# 3SV53-10137, PMC Power Motive, Cummins Turbo Diesel Engine, (A59076)
2014 Sakai SV540T...
LOT OF AIR GUNS & HAND TOOLS (A58374)
LOT OF AIR GUNS &...
