bobcat S-150
   / bobcat S-150 #1
gulit1
bobcat s-150
Hello All.
I am new member. I want to buy used S-150 2005 year and 1036 hours.Condition is written exellent.I need advice. Is it OK mashine for this price(10900$)? I will use it in small construction area. Is it possible to use this mashine for 3-4 years without big problem?Could you please tell me couple words about fuel consumption.
   / bobcat S-150 #2
1036 hrs. is not a lot of hours on that machine for it's age. That S-150 has a Kubota V2203 engine, hydrostatic drive system is same as used in this size machine since introduction of the 753 in 1991. If there were any reliabilty problems Bobcat would have changed systems by now. Keep the fuel clean, grease it well regularly, and change oil & filters as recommended in Op manual. As far as price goes, that depends on area of country you are in, but if it is in good as shape as advertised sounds like you won't go wrong.
S-150 is a 773/S-175 with a radius lift arm. 773, S-175 same powertrain but have vertical lift path boom.
   / bobcat S-150
Thank you SSdoxie.
   / bobcat S-150 #4
Only other different if the 773 and S 175 are turbocharged while the 150 is not.
NEW Woods 6ft Finish Mower (A53473)
NEW Woods 6ft...
2012 CHANDLER 130 BBL STEEL VACUUM TRAILER (A53843)
2012 CHANDLER 130...
2012 Ram 3500 Crew Cab Flat Bed Truck (A53422)
2012 Ram 3500 Crew...
2021 ALLIANCE NORTH AMERICA, INC AIRMAN SDG45 GENERATOR (A53843)
2021 ALLIANCE...
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A51691)
2024 Wanco...
