bobcat S-150
   / bobcat S-150 #1
gulit1
bobcat s-150
Hello All.
I am new member. I want to buy used S-150 2005 year and 1036 hours.Condition is written exellent.I need advice. Is it OK mashine for this price(10900$)? I will use it in small construction area. Is it possible to use this mashine for 3-4 years without big problem?Could you please tell me couple words about fuel consumption.
   / bobcat S-150 #2
1036 hrs. is not a lot of hours on that machine for it's age. That S-150 has a Kubota V2203 engine, hydrostatic drive system is same as used in this size machine since introduction of the 753 in 1991. If there were any reliabilty problems Bobcat would have changed systems by now. Keep the fuel clean, grease it well regularly, and change oil & filters as recommended in Op manual. As far as price goes, that depends on area of country you are in, but if it is in good as shape as advertised sounds like you won't go wrong.
S-150 is a 773/S-175 with a radius lift arm. 773, S-175 same powertrain but have vertical lift path boom.
   / bobcat S-150
Thank you SSdoxie.
   / bobcat S-150 #4
Only other different if the 773 and S 175 are turbocharged while the 150 is not.
2019 CATERPILLAR 926M WHEEL LOADER (A52705)
2019 CATERPILLAR...
2023 CATERPILLAR 259D3 SKID STEER (A52705)
2023 CATERPILLAR...
2016 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A54607)
2016 FREIGHTLINER...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
2012 International 4300 Reefer Truck (A53473)
2012 International...
