Found this case of grease
   / Found this case of grease #21
I have a JD 60-inch 7-Iron deck, and every spring I pump a half tube of Deere premium grease into each of the three mower spindles. I cannot understand why it continues to take grease when there is no way any leaks out. I never see any leaking out of the spindle, top or bottom...may be a dumb question but WHERE does the grease I keep pumping in go? The manual for the mower gives me no indication of how much to add. Seems to me that after 8 years the spindles should be really full.
   / Found this case of grease #22
It may be coming out of the exhaust pipe by now.:laughing::laughing: Have you checked there lately.
   / Found this case of grease #23
The grease from my spindles expels at the lower part of the spindle. Never noticed any grease on the grass. yeap, when i put in a bearing, I either prick a couple holes in the seal or remove it completely. Lately the bearing are made in china, so they are probably softer material.I only use this practice of altering bearing seals on my mowing equipment spindles. I grease the tractor about 10 hours use..Jy.
   / Found this case of grease #25
SHOOT....THAT would explain why the FEL assemblies under the exhaust pipe get dirty so fast...actually, I have NEVER found any grease underneath the deck but it may be so covered with grass and dirt when I power wash it every fall, the grease cannot be seen.
   / Found this case of grease #26
hey JD,I know when I grease my Grasshopper I know when they are full because it flows out underneath.Seems deceptive to put zirks on a sealed bearing. russ
CATERPILLAR 313FL EXCAVATOR (A60429)
CATERPILLAR 313FL...
Adams Tilt Trailer (A56438)
Adams Tilt Trailer...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2008 INTERNATIONAL...
2024 CATERPILLAR 930 AG HANDLER WHEEL LOADER (A52709)
2024 CATERPILLAR...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
2020 DRAGON ESP...
