correct gear lube
   / correct gear lube #1
citytransplant
Central New York
Farmtrac 270DTC
I just purchased a new Leinbach PHD and the gearbox is dry. Manual says use 90 weight gear oil. I have an unopened bottle of Super Tech synthetic blend SAE 75W-90. "A multi-purpose, extreme pressure (EP) gear lubricant to be used where API GL-5 lubricants are recommended."
Duh... does the 75W part of 75W-90 mean 75 weight? Can I use this lubricant for this application?
Thanks!
   / correct gear lube #2
That should work just fine.
   / correct gear lube #3
I think it means that it's 75 weight at 0 degrees F and 90 weight at a higher temperature, like 210F or something similar.
   / correct gear lube #4
Thanks!
Not the best fluid, but yes, it will work. In the winter in NY, might flow a little slow until warm.
   / correct gear lube
Thanks to all. What are some of the better brands of 90W gear oil?
   / correct gear lube #6
your synthetic 75 w 90 is arguaply a BETTER lube than a plain 90w.. and it should flow nicely in arctic winter.. thus th elower first number and the fact it is synthetic.
our big dump trucks now spec 75w90 ONLY in their rear and rear rear ends..
that should tell you somehting.
soudnguy
   / correct gear lube #7
soudnguy
You get arctic weather down there??????:D:laughing:;)
   / correct gear lube #8
this winter we had single digits.
it's a well known fact that many go for synthetic for cold pour point viscosity and better residual lube film strength on gears .. which makes for less wear at startup and in cold climates.
the data is out there.. read it
soundguy
   / correct gear lube #9
Thanks!
Just dump it in. Weight doesn't matter much. As long as it is 'EP' rated (aka GL-5), that is all you need to worry about. Also, as far as quality goes, Supertech oil is just fine.
JayC
   / correct gear lube #10
soundguy
Read about bone chilling temps in Florida?? This is a post hole digger...no? less wear at startup... what start-up?:confused2:
getting deep here... real deep here.... need high boots.
91013 (A48082)
91013 (A48082)
2018 JCBTruss Jib Telescopic Hyrualic Boom (A53421)
2018 JCBTruss Jib...
2018 Caterpillar 308E2 CR Midi Excavator (A52377)
2018 Caterpillar...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
1993 Ford F-150 Pickup Truck (A52377)
1993 Ford F-150...
U56 DIESEL FIRE PUMP (A51406)
U56 DIESEL FIRE...
