Price Check B3200
   / B3200 #1
Sackperson
I am in the process of purchasing a new B3200, LA504, LP 5' finish mower, and LP 5' Box Blade. Quote price is $18,000.00. Sound good?
Thanks!
   / B3200 #3
Thanks!
We pay more than that for just the tractor and loader up here in the frozen north. Good grief can't believe how we get screwed every time we turn around.
   / B3200 #4
It seems like an outstanding deal to me. The tractor and FEL is listing for $20K, so to get the LP box blade & RFM for $18K seems like a really good deal.
If you have not already done so, I would suggest you test the tractor with the RPM up to near the PTO RPM speed and make sure you are comfortable with the vibration of the 4 cyl diesel.
   / B3200 #5
If you have not already done so, I would suggest you test the tractor with the RPM up to near the PTO RPM speed and make sure you are comfortable with the vibration of the 4 cyl diesel.[/QUOTE]
I agree with that suggestion. Just a few of my comments about the vibration.
With the loader there are lots of places for 'noise' which always seems to make a vibration seem worse. A little time spent eliminating the noise and some of the vibration goes away. Also this may be all in my head but with mine the vibration does not seem as bad as when it was brand new.:confused2:
They are a great tractor and I love the extra power to weight that this unit has. I am always finding new uses for it because it is a real powerhouse.:D
   / B3200 #6
I had a B3200 and never noticed the vibration problem at the RPM's I operated at. I've never been a full throttle man so maybe it was at that point which I never hit. It was a fine tractor.
   / B3200 #7
I would have to agree with JT, as I have the B3200 TLB and it really is a sweet running tractor I have not noticed any vibration from the 4 cylinder motor.
DevilDog
   / B3200 #8
DevilDog
The only time mine was noticeable was over 2000rpm usually from 22-2600rpm.
The only time I need that rpm is for pto work that requires the speed otherwise I always run below 2k. It has so much grrrr that high rpm is not needed. It really is a nice tractor.:thumbsup:
   / B3200 #9
Thanks!
XXXXXXX
two months ago I paid $19,000 for a B3200 HST with ag tires, a KK HD disc and a KK 5' bush hog. And I had to go pick it up and bring it home. Sounds reasonable to me.
BTW, my 3200 has done everthing I need(ed) it to and then some. I wish I had spent the extra money and gotten a back hoe though.
CB
2012 Dodge Ram 1500 Tradesman Crew Cab Pickup Truck (A55788)
2012 Dodge Ram...
1838 (A51248)
1838 (A51248)
2001 Volvo A25C 6x6 Haul Truck (RIDE AND DRIVE) (A50775)
2001 Volvo A25C...
2013 MACK GU (GRANITE) TRI AXLE WINCH TRUCK (A55745)
2013 MACK GU...
2007 Dodge Ram 2500 (A53314)
2007 Dodge Ram...
INDUSTRIAS AMERICA F12T HYD TILT LAND LEVELER (A51406)
INDUSTRIAS AMERICA...
