Bedder/Hiller furrow attachment
   / Bedder/Hiller furrow attachment #1
Haywire
Central Kentucky
Tractorless :(
I am wondering why the furrowing attachment on these are forward of the disks. Looks like in the video the disks just cover up any furrow the shovel may try to make. At the end of the video, they stop using them together and raise the disks for a second run with just the furrower down. Seems to me that if they mounted the shovel behind the disks, it could be a one run and done implement.
Ian
attachment.php
   / Bedder/Hiller furrow attachment #2
I think the idea is to shatter the ground in front of the discs so the discs are not smearing the soil to break it loose. If I understand the useage of this implement you want the furrower to break up the soil and the discs to pile it up in a hill. That way you'd get less "plow pan" from the disc shearing/smearing the soil at the lowest point of contact. If I have that all wrong, please straighten me out 'cause I want to build one of these, but I want to know the "why" before I do the "do" and build it.
-Jim
   / Bedder/Hiller furrow attachment #3
We have sold around 20 of these in the last week $20 each and the are double spring and some have pretty good points on them. Ken Sweet
-Jim
My thinking is that if you are using the furrower attachment, it's right after tilling so the ground is powder anyway. I could see something like a cultivator shovel ahead of them if you are hilling potatoes, but you'd need two of them out at the edges for that, not running the center where the plants are.
I don't know... I'm learning as I'm going. :) Have you watched the Everything Attachments video? They explain what the furrower is used for there.
Ian
   / Bedder/Hiller furrow attachment #5
Ian
Well I'll be dipped. Just watched the video and I think I overthought this. Seems like the furrower is there just for making a furrow to plant in. Based on that, I'd have to agree, Ian - I'd put the furrower aft of the discs. I suspect the implement maker puts it foreward to use less steel/keep cost competitive. I have also seen these setups with some points/sweeps outboard to break up the tire tracks.
   / Bedder/Hiller furrow attachment #6
After watching the video I am left wanting the attachment to have the furrower BOTH in front of the hiller discs and behind them (two furrowers). Ted solves the problem with a second pass with the hiller discs raised. But then he points out that Peanut got off the track a bit. If the furrower was mounted behind the hillers you would get what you wanted in the first pass.
   / Bedder/Hiller furrow attachment #7
I built mine from an old cultivator, a couple of discs, and a couple of bearings. I tried the cultivator tine that I use for a furrower on front and back, only back worked. HOWEVER, I've since removed it and replaced it with a rolling section of drain pipe filled with concrete to compact soil on the hill a bit. I don't plant everything in furrows, and find the compression more useful on a single pass. A planter or hoe makes quick work of a furrow, and your depth is easier to control.
   / Bedder/Hiller furrow attachment #8
I like the idea of the rolling pipe. You could add a piece of soft copper pipe wrapped around the center of that roller to create a perfectly centered planting line impression. It would be small enough to drop seeds into it, or just as a line to set plants.
   / Bedder/Hiller furrow attachment #9
Thanks, Ford850. Makes sense--I hadn't thought of putting a circumferential ridge on my roller. I'll try that. I have to rehill part of the garden anyway. We had 2" of rain in a couple of hours this week, so I have a couple of washouts.
Could you post some pics of the roller setup and what the hill looks like afterward?
thanks,
Ian
   / Bedder/Hiller furrow attachment #11
Here you are, Haywire. I don't have a picture of the roller, but these are the results. In this garden, there are 13, 60' rows. I don't have a pic of the roller, but it's simple. I used a 2' long piece of 4" PVC drain pipe, put a cap with a hole in the center on each end. Through those holes I ran a piece of 1/2" PVC pipe to serve as a channel for the axle, loosened the cap, filled the larger pipe with concrete, put the cap back on. The axle is just an old piece of steel rod.
I then used some scrap steel straps to attach each end of the axle to the back of the hiller, so the roller floats behind it without twisting.
Another poster, in a long-ago thread, demonstrated how to mount the hiller behind the tiller, so no tire tracks remain. Maybe next year.
   / Bedder/Hiller furrow attachment #12
Great lookin' attachment for homemade. Gives me some good ideas. Thanks for posting.
   / Bedder/Hiller furrow attachment #13
Ian
Seems like I read a thread that moved the furrowing tool to the back. This looks lit it was from the prototype and original designs. Works much better in the bacd. Might have been an EA thread but can't remember,
2015 Vermeer D9X13III Directional Boring Machine (A59228)
2015 Vermeer...
2023 VOLVO ECR25 ELECTRIC EXCAVATOR (A60429)
2023 VOLVO ECR25...
2001 John Deere 6210 (A60462)
2001 John Deere...
JOHN DEERE 624K WHEEL LOADER (A58214)
JOHN DEERE 624K...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2019 INTERNATIONAL...
LAND PRIDE RCR1260 5' ROTARY MOWER (A59823)
LAND PRIDE RCR1260...
