I wanted a new plow but I couldn't afford it so
   / I wanted a new plow but I couldn't afford it so #11
7' blade works well on a 35 hp tractor, sometimes an 8' would be nice with 35hp.
I would go at least 8' if not 9', with your tractor.
Look at the model number of the blade you are talking about; RB3584
RB = Rear Blade
35 = 35 hp
84 = 84"/7'
RB = Rear Blade
35 = 35 hp
84 = 84"/7'
The 84 does indeed indicate the width but the 35 is a number for the lower end horsepower rating.
The blade is rated for "up to" 80 hp in a two wheel drive and "up to" 65 in 4w drive.
As far as the width, I was actually more concerned about pushing the tractor sideways than I was covering my tires or being able to pull it.
My six footer pushed my "little" GL3240 sideways like crazy if I got too happy with it.
:laughing:
That sure is a fine rear blade. Being hydraulically adjustable it may not be an issue but I like to turn my blade 180 degrees for some applications. If the blade is too wide you can only do that with it removed from the tractor. Nybirdman makes a good point. You want it to cover your foot print when angled. Bet you knew that.
MarkV
From the 3pt hitch to the hinge pin is 61 1/8 inches. And 8 footer only needs 48 inches to spin around. To turn it, you unhook the cylinder, whirl it around and re-pin the cylinder. Piece of cake. :thumbsup:
   / I wanted a new plow but I couldn't afford it so #16
:laughing:
From the Land Pride catalog's Rear Blades pages:
Series / HP range
RB05 / 17 -25
RB15 & RBT15 / 17 - 40
RB25 / 25 - 60
RB35 / 35 - 80
RBT35 / 35 - 80
RBT40 / 65 - 100
RBT45 / 70 - 125
RBT55 / 90 - 180
   / I wanted a new plow but I couldn't afford it so #17
It helps if the blade extends beyond the tires, so that you don't have to drive on the windrow that you are trying to move over. Loaded tires will keep the tractor from sliding sideways.
If you snag something solid with a 35-80 hp rated blade using a 50+ hp tractor, you will tear the swivel post right off of the 3pt frame. BTDT.
My tires are loaded. Wouldn't have it any other way. :)
You tore one up!!!???? :shocked:
Holy broke blade batman.
So, Maybe I need to consider moving up to the 40 series.
Dang, there goes that money issue again.:mur:
   / I wanted a new plow but I couldn't afford it so #19
I have a 4720 Tractor which is 72" wide and an 8' wide landpride blade that I use to pull snow.....works awesome. I have two hydro cylinders on mine. If I had it to do over again I would by the 9'......sometimes when angled sharp for deep snow I don't cover my tracks. But 95% of the time it is great...
   / I wanted a new plow but I couldn't afford it so #20
I have the 35 series on my tractor. It is a heavy tough blad....I can't imagine you are going to bend it. I have angled and swung mine on an end angle to pull trenches in hard dirt and it held up fine. I would not want a heavier one for what I do. This one already is heavy enough that you need be real careful when using on concrete for pulling snow.
MISC CABINET PARTS (A54757)
MISC CABINET PARTS...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2007 IC Corporation PB105 School Bus (A55852)
2007 IC...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2025 JMR 36in Mini Skid Steer Bucket (A55787)
2025 JMR 36in Mini...
