BX1860 54" deck and Gator blades
   / BX1860 54" deck and Gator blades #21
I sent a set of the gator blades back to Baileys today. I have a 54" deck on my BX1500 and the arbor is 7/8" or 0.875". The gator blades that the parts books called were 1 1/8" so it was a no go. I didn't want to use the bushing trick. So I sent the gator blades back and ordered a set of standard blades form a Kubota dealer. Oregon does not make a 7/8 arbor gator or regular blade in the 18 5/8" length.
   / BX1860 54" deck and Gator blades #22
Yeah thats why the ones that I got are 23/32'' or .72, which some people claimed will fit while others said they had to enlarge the hole (which I may be ok with).
   / BX1860 54" deck and Gator blades #23
Does the gator blades load the engine more? I ask because the BX1500 is not loaded with HP. Does a good job mind you but I would not want to add more load.
   / BX1860 54" deck and Gator blades #24
I can't say that they do on my machine, although they are much heavier than stock blades (wider)
Definitly not, that engine has so much torque that I never had any bogging issues even in heavy tall grass.
   / BX1860 54" deck and Gator blades #27
So according to the plaque on the mower I have a RCK54P-23BX.
I received the gator blades today (396-748) and they did not fit. I am going to have to have someone drill a larger hole into them.
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A53472)
Mitsubishi FG35...
(1) 275 Gallons of Aluminum Brightener (A51573)
(1) 275 Gallons of...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A53472)
GOODYEAR SET OF...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
APPROX 500 GALLON FUEL TANK (A51248)
APPROX 500 GALLON...
14ft Bi-Parting Iron Gate (Cow Design) (A51573)
14ft Bi-Parting...
