BX1860 54" deck and Gator blades
   / BX1860 54" deck and Gator blades #21
I sent a set of the gator blades back to Baileys today. I have a 54" deck on my BX1500 and the arbor is 7/8" or 0.875". The gator blades that the parts books called were 1 1/8" so it was a no go. I didn't want to use the bushing trick. So I sent the gator blades back and ordered a set of standard blades form a Kubota dealer. Oregon does not make a 7/8 arbor gator or regular blade in the 18 5/8" length.
   / BX1860 54" deck and Gator blades #22
Yeah thats why the ones that I got are 23/32'' or .72, which some people claimed will fit while others said they had to enlarge the hole (which I may be ok with).
   / BX1860 54" deck and Gator blades #23
Does the gator blades load the engine more? I ask because the BX1500 is not loaded with HP. Does a good job mind you but I would not want to add more load.
   / BX1860 54" deck and Gator blades #24
I can't say that they do on my machine, although they are much heavier than stock blades (wider)
Definitly not, that engine has so much torque that I never had any bogging issues even in heavy tall grass.
   / BX1860 54" deck and Gator blades #27
So according to the plaque on the mower I have a RCK54P-23BX.
I received the gator blades today (396-748) and they did not fit. I am going to have to have someone drill a larger hole into them.
8" & 10" I BEAMS UP TO 102" LONG (A51247)
8" & 10" I BEAMS...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
2016 JOHN DEERE 624K WHEEL LOADER (A51246)
2016 JOHN DEERE...
UNUSED SWICT 84" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 84"...
MURRAY 22" GAS PUSH MOWER (A51248)
MURRAY 22" GAS...
