The BX25's going to be getting some work done...
   / The BX25's going to be getting some work done... #1
CompactTractorFan
Super Member
Pennsylvania
Kubota BX25
She's going to be leaving us for a few days soon to get a new radiator shroud and new seat belt installed. :(
   / The BX25's going to be getting some work done... #2
OK: I bet there is a story leading up these repairs:licking:
   / The BX25's going to be getting some work done... #3
What happend? :confused:
Well, these things have been broken for a while...Still not sure what happened to the radiator...When plowing snow a few months ago I hit a bump with the FEL and that's when the radiator shroud broke. Still not sure what exactly broke it...:confused: Oh...the seat belt...Well, the holder that guides when it retracts is broken causing the seatbelt to jam...How that broke...Well...I...Uh...Kinda of sat on it...:ashamed: Also, we are getting a new mounting part for the MMM that broke when someone left it on after the mower was removed and jammed it in to the asphalt driveway while in transit...;):ashamed:
   / The BX25's going to be getting some work done... #5
Have you considered removing the asphalt to eliminate future problems?
Better add two grease zerks for the MMM anti-scalp wheels...:ashamed:
   / The BX25's going to be getting some work done... #8
adding zerks back into the plastic wheels? wont work. they just push in. I been meaning to buy larry's axles or have mine retrofitted to have zerk right ON the axle shaft, not stupid plastic wheels.
Well, I was greasing them and two of them came right off with the gun...:confused2:
The BX25 and our chipper are going to be picked up Thursday. They should be back home within 5-7 business days. :thumbsup:
2009 Freightliner Columbia 120  10-Speed, Mercedes MBE4000, 6x4 (A51039)
2009 Freightliner...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2018 CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A51242)
2018 CATERPILLAR...
2015 Lexus RX 350 SUV (A48082)
2015 Lexus RX 350...
1500 Gallon Water / Chemical Tank (A50860)
1500 Gallon Water...
2017 Peterbilt 567 Tri-Axle Dump Truck (A48081)
2017 Peterbilt 567...
