Dewalt 14" chop saw blade suggestions
   / Dewalt 14" chop saw blade suggestions #21
Try the dreaded HF blades. Cheap, will do the job and will fit the saw.
Also, agree with the others who stated (not verbatim) way to try not to cut on the flats and stand it up, Much faster.... Too much pressure at the start of the cut and the blade can walk but I've never had it walk from too much pressure after the cut was started, if that makes any sense to you :)
   / Dewalt 14" chop saw blade suggestions #22
Looks similar to the inflated HP that the compressor manufacturers tried to feed to consumers.
15A @ 120V is 1800 watts. At 746 watts/HP, that equals 2.4 HP and that's before the efficiency of the motor is factored in. Once the efficiency of the motor is taken into account, it will probably be about 2 HP at the most.
You didn't factor in the really small horses they have in China...:)
I agree... It's probably like those 6hp 22" cut push mowers that don't have the grunt that the 3.5 hp mowers had when I was a kid.
Ian
   / Dewalt 14" chop saw blade suggestions #24
Ian
I am thread drifting here, but here goes anyways. Also I will more than likely get kicked about the design aspects by some not looking into the physical performance.
Older lawn mowers used Straight Blades keeping the blades impact surface and drag surface to a minimum. This type of blade requires less horse power to cut through grass, but in turn does not mulch and may require raking and bagging the clippings if they bother you.
The new High Tech, High Lift Blade designs do help mulch and give a little more appealing finish cut, at a price of more fuel used per cut and more frequent cutting intervals.
My High Lift finish mower blades have a height of 1 inch, I made a set of Straight Blades with a height of 1/4 inch. The performance difference between the two, using my little 16HP CUT is HUGE. I run at lower RPM's, and a higher gear with practically no bogging down when hitting thick grass. With the High Lift Blades I would need to down shift and increase RPM's, which helped, but at times the deck would load up and bog down anyway.
The results are, I have less seat time cutting and I am burning less diesel fuel. With the 10+ acres I keep cut, it has been worth every bit of research I did before doing it. The benefits out weigh any argument of High Lift Blades for my use.
Sorry for the thread drift, I do think the Original Poster had his question answered already.
   / Dewalt 14" chop saw blade suggestions #25
I have to agree with Mace. Somewhere there is probably a disclaimer that they are stating starting amp surge. Either that or it's the smaller horses.:laughing:
Hydraulic Hose Reel (A52377)
Hydraulic Hose...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
New Holland 650 (A50123)
New Holland 650...
Ford Super Duty Pickup Truck Bed (A51692)
Ford Super Duty...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
2012 Dodge Charger Sedan (A51694)
2012 Dodge Charger...
