discbine
   / discbine #6
New machine JD600 series and the vermeer mc840
JD 630- 9'9"
MC 840- 10'6"
JD630 - CV PTO optional- mows only out to the side
MC840 CV PTO Standard- mows directly behind the tractor or out to the side.
Can be changed on the fly. Cutterbar angle is hydraulically adjustable on-the-go.
JD630- urethane rollers
MC840- Steel Rollers
JD630- Cast Impellers
MC840- Spring Steel Paddles
JD630-Rear Spring float
MC840- Vermeer DynaGuardSuspension!
Allows the cutterhead to swing back, up and
over obstacles, then quickly return to its original setting.
JD630- Gear drive segments with multiple seals- gear oil 7.4 qts.
MC840- Multiple Shaft design with each cutting head unit sealed using
EP-0 grease for lube
Both machines are premium quality units.
2008 Ford Focus SEL Sedan (A55853)
2008 Ford Focus...
2024 JOHN DEERE 6110M LOT NUMBER 56 (A53084)
2024 JOHN DEERE...
BUYER'S PREMIUM INFO LOT NUMBER 2 (A53084)
BUYER'S PREMIUM...
(2) PALLETS OF TRAILER JACKS & MISC TRAILER PARTS (A54757)
(2) PALLETS OF...
