discbine
/ discbine #6
New machine JD600 series and the vermeer mc840
JD 630- 9'9"
MC 840- 10'6"
JD630 - CV PTO optional- mows only out to the side
MC840 CV PTO Standard- mows directly behind the tractor or out to the side.
Can be changed on the fly. Cutterbar angle is hydraulically adjustable on-the-go.
JD630- urethane rollers
MC840- Steel Rollers
JD630- Cast Impellers
MC840- Spring Steel Paddles
JD630-Rear Spring float
MC840- Vermeer DynaGuardSuspension!
Allows the cutterhead to swing back, up and
over obstacles, then quickly return to its original setting.
JD630- Gear drive segments with multiple seals- gear oil 7.4 qts.
MC840- Multiple Shaft design with each cutting head unit sealed using
EP-0 grease for lube
Both machines are premium quality units.
2010 Workhorse Custom Chassis W62 Delivery Truck with Liftgate (A61573)
2010 Workhorse...
2022 MORBARK EAGER BEEVER 1215 WOOD CHIPPER (A63276)
2022 MORBARK EAGER...
UNUSED SDLANCH ELECTRIC GOLF CART (A64280)
UNUSED SDLANCH...
2020 HYDREMA 922G HM ARTICULATING DUMP TRUCK (A65053)
2020 HYDREMA 922G...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A61568)
2008 Ford F-550...
2022 EZ-GO ELITE...
