Another R4/Turf Loaded or not question
   / Another R4/Turf Loaded or not question
I ordered filled R4's, sounds like it's a good compromise given I want to do a mix of FEL work and some mowing. I'll throw in my 2 cents once I have some hours on them. Thanks
   / Another R4/Turf Loaded or not question #12
You'll be fine, but get that ballast box!!
   / Another R4/Turf Loaded or not question #13
+1 Roy!! I think many new owners feel like if they load their rear tires they are good for any loader work they want to do. Not so! Loaded tires sure help and I would not be without them but you still need to counter balance the front with something in the back if you want to max out your loaders capabilities safely.
MarkV
   / Another R4/Turf Loaded or not question #14
I do loader and push snow as well a use rear blower. Loaded turfs + 300 lb weight do just fine with the loader.
Chains work real good on turfs for snow and ice surfaces come winter and the blower replaces the rear weight.
All in all I think I have a good combination for all around work, both winter and summer.
(Knock on wood) I have never been stuck nor do I mess up my lawn.
On grass I always use 2 WD as it is the 4 WD that chews up the grass when turning.
My biggest fear is punctures due to fact that turfs have less plies but so far no problems.
Looking at treads, turfs look more like snow tires than R4's which due to large flat knobs that look like 1/2 slicks.
Of coarse this discussion usually ends up like Ford vs GMC vs Dodge.
2024 JOHN DEERE 1025R LOT NUMBER 106 (A53084)
2024 JOHN DEERE...
1982 LeeBoy Motor Grader (A55218)
1982 LeeBoy Motor...
2014 Ford Fusion SE Sedan (A53424)
2014 Ford Fusion...
2015 PCI MFG. SOLUTIONS 130 BBL STEEL VACUUM TRAILER (A53843)
2015 PCI MFG...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2015 FREIGHTLINER...
2021 Toyota Corolla LE Sedan (A53424)
2021 Toyota...
