Another R4/Turf Loaded or not question
   / Another R4/Turf Loaded or not question
I ordered filled R4's, sounds like it's a good compromise given I want to do a mix of FEL work and some mowing. I'll throw in my 2 cents once I have some hours on them. Thanks
   / Another R4/Turf Loaded or not question #12
You'll be fine, but get that ballast box!!
   / Another R4/Turf Loaded or not question #13
+1 Roy!! I think many new owners feel like if they load their rear tires they are good for any loader work they want to do. Not so! Loaded tires sure help and I would not be without them but you still need to counter balance the front with something in the back if you want to max out your loaders capabilities safely.
MarkV
   / Another R4/Turf Loaded or not question #14
I do loader and push snow as well a use rear blower. Loaded turfs + 300 lb weight do just fine with the loader.
Chains work real good on turfs for snow and ice surfaces come winter and the blower replaces the rear weight.
All in all I think I have a good combination for all around work, both winter and summer.
(Knock on wood) I have never been stuck nor do I mess up my lawn.
On grass I always use 2 WD as it is the 4 WD that chews up the grass when turning.
My biggest fear is punctures due to fact that turfs have less plies but so far no problems.
Looking at treads, turfs look more like snow tires than R4's which due to large flat knobs that look like 1/2 slicks.
Of coarse this discussion usually ends up like Ford vs GMC vs Dodge.
2016 CATERPILLAR D5K2 XL CRAWLER DOZER (A52706)
2016 CATERPILLAR...
2015 Ford F-250 Ext. Cab 4x4 Flatbed Truck (A53422)
2015 Ford F-250...
UNUSED WOLVERINE CB-11-750F HYD CONCRETE BREAKER (A54757)
UNUSED WOLVERINE...
2017 Ford F-450 Crew Cab Mason Dump Truck (A53422)
2017 Ford F-450...
John Deere (A50322)
John Deere (A50322)
