Where do you draw the line between a garden tractor and a CUT?
   / Where do you draw the line between a garden tractor and a CUT? #111
wonder if there is a sticky section? that this thread could go into?
   / Where do you draw the line between a garden tractor and a CUT? #112
A lawn tractor cuts lawns.
A garden tractor can cut lawns and can do some light ground engaging work.
A CUT can do heavier ground engaging work and has a PTO & Class 1 hitch.
   / Where do you draw the line between a garden tractor and a CUT? #113
They are both toys. lololol:D
   / Where do you draw the line between a garden tractor and a CUT? #114
Mine has been called a toy tractor, but I'm ok with it cause the same guy calls his Peterbuilt a big car.
   / Where do you draw the line between a garden tractor and a CUT? #115
I believe that Deere currently draws the line based on the 3PH. SCUT has a limited category 1, CUT has a full category 1. Anything with category 2 and up is an ag tractor.
   / Where do you draw the line between a garden tractor and a CUT? #116
If it comes with a cutting deck and blades already attached in between the tires,its a mower! Come on guys! What came first the chicken or the egg?
I started this thread and will excuse you asking about the "chicken and the egg" thing as you are a newbie here...and exactly what does "mower" have to do with the distinction between GT and CUT?
   / Where do you draw the line between a garden tractor and a CUT? #118
categories are in following sequence
-lawn tractor, no three point hitch, no pto, cuts lawn only
-garden tractor, category zero three point hitch, may have pto, may have front end loader, may have a mid mower, may have a rear mower
-small utility tractor, most likely category one three point hitch, should have pto, may have front end loader, may have mid mower, could attach rear mower.
-then comes category two three point hitch, etc
   / Where do you draw the line between a garden tractor and a CUT? #119
"If the manual says it is not for ground engaging tools, it is a lawnmower.":confused2:
Let me get this straight...you joined back in June of 2010, yet this is your first post? Welcome to TBN, and let me congratulate you on that. Too bad you didn;t join this discussion sooner as we could have used your input. I also started the same thread over on www.lawnmowerforum.com and on that site, as well as here, the issue opened a whole can of worms.
8ft Forklift Safety Basket Attachment (A51691)
8ft Forklift...
THRESHOLD 30" SQUARE OUTDOOR GAS FIRE TABLE (A51248)
THRESHOLD 30"...
2001 Nissan Frontier Crew Cab Pickup Truck (A51692)
2001 Nissan...
2012 Big Tex T/A 20 ft. Gooseneck Trailer (A53117)
2012 Big Tex T/A...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
6" & 10" I BEAMS UP TO 40' LONG & MISC (A51247)
6" & 10" I BEAMS...
