Can you identify this Implement
   / Can you identify this Implement #1
sweettractors
Advertiser
Central Kentucky
JD 6403 CHA-JD 3130 CHA
Can anyone identify what it is and the brand? The fellow I bought it from thought it was a Ford Brand and he used it to renovate pastures and drag fields down after plowing? A cylinder can be used to raise and lower it on corners or maybe a ratchet jack. I don't know if it shows in the picture, however, on the bottom side, there are many U shaped pieces bolted on with 1 bolt so they can pivot. Looks almost like 3 or 4 inch channel iron. These slice the ground as it glides over it. The top is designed so that rocks could be put in and held until you could get to a offload place. It is a factory built unit. I know what it can and has been used for, I would like to nail down the technical name and brand? Ken Sweet
   / Can you identify this Implement #2
You are crazy Ken, buyin' stuff not even knowin' what it is! :laughing:
The consensus on the YT forum is that this is called a "Soil Surgeon" used for leveling out a plowed field that had a lot of top growth before plowing. slices, cuts and seals off the field to promote the breakdown of turned organic material faster. Still not 100% sure about the brand? Ken Sweet
   / Can you identify this Implement #6
Yeah, good enough :thumbsup: For now you'll have to sell it as a thing-a-ma-jigger that does this & that ...
Looks like he may need to find the six 'hicky-things', that are missing on that thing-a-ma-jigger , in order to sell it.
   / Can you identify this Implement #7
My first instinct was Shultz, although I've never seen that implement before.
I may sell it to a new owner and let him fab up 6 slicers from chanel iron and keep the price lower. Ken Sweet
London Fog 18-20 Mosquito Machine (A50860)
London Fog 18-20...
CATALOG IS A GUIDE ONLY!! (A50775)
CATALOG IS A GUIDE...
2016 Ottawa Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, 33,000 ... (A51039)
2016 Ottawa Yard...
2022 Continental 16' Enclosed Trailer with ramps (A49461)
2022 Continental...
2002 International 4400 SBA 4x2 (A49461)
2002 International...
2014 Dynapac CC4200 (A51039)
2014 Dynapac...
