Can you identify this Implement
/ Can you identify this Implement #1
sweettractors
Advertiser
Central Kentucky
JD 6403 CHA-JD 3130 CHA
Can anyone identify what it is and the brand? The fellow I bought it from thought it was a Ford Brand and he used it to renovate pastures and drag fields down after plowing? A cylinder can be used to raise and lower it on corners or maybe a ratchet jack. I don't know if it shows in the picture, however, on the bottom side, there are many U shaped pieces bolted on with 1 bolt so they can pivot. Looks almost like 3 or 4 inch channel iron. These slice the ground as it glides over it. The top is designed so that rocks could be put in and held until you could get to a offload place. It is a factory built unit. I know what it can and has been used for, I would like to nail down the technical name and brand? Ken Sweet
/ Can you identify this Implement #2
You are crazy Ken, buyin' stuff not even knowin' what it is! :laughing:
The consensus on the YT forum is that this is called a "Soil Surgeon" used for leveling out a plowed field that had a lot of top growth before plowing. slices, cuts and seals off the field to promote the breakdown of turned organic material faster. Still not 100% sure about the brand? Ken Sweet
/ Can you identify this Implement #6
Yeah, good enough :thumbsup: For now you'll have to sell it as a thing-a-ma-jigger that does this & that ...
Looks like he may need to find the six 'hicky-things', that are missing on that thing-a-ma-jigger , in order to sell it.
/ Can you identify this Implement #7
My first instinct was Shultz, although I've never seen that implement before.
I may sell it to a new owner and let him fab up 6 slicers from chanel iron and keep the price lower. Ken Sweet
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A59228)
Challenger MT275B...
Atlas Copco Air Compressor & Air Dryer (A62613)
Atlas Copco Air...
