Clumber
Gold Member
I used my new 48' brush cutter for the first tine yesterday. With tractor running at full throttle, I switch-on the PTO switch to hear a loud bang as the hyd motor engaged. It run smoothly and quietly after starting. Is the bang normal? The bang happens every time it starts.
I shutdown to look under the deck and it looked okay so i continued It does a very nice cut for a brush cutter on the overgrown lawn and plows through thick brush easily. There are two swing blades on the "turret". But there are four bolts. Is that a normal setup? Is it possible to add two more blades? I would not think more blades are necessary, since it cut so well with two.
