Lawn Roller: Fill w/other than H20?
   / Lawn Roller: Fill w/other than H20? #11
The concrete would make a fairly heavy roller but fwiw,, filling with weight material for drilling mud would be almost twice that. Bayrite weight material comes in at 36lbs/gallon, that would make this a 3000 lb roller. 100lb sacks of this stuff are tiny compared to things like fertilizer.
I belive i have this figured at approximately 1650lb +/-. I am a litle concerned on some parts of the gravel driveway the slop might be too steep for this. But I guess I could pull it behind my '79 FJ40 if that were the case.
I was suprised at how many bags it would take!
   / Lawn Roller: Fill w/other than H20? #13
Does that harden like concrete, and I assume it does, but what does that cost roughly compared to concrete. That sounds like something I have to remember.
   / Lawn Roller: Fill w/other than H20? #14
This is more like stone dust, doesn't harden but makes a very heavy mud that will settleout quickly in water. Since it is used in the oil field I haven't ever had to buy it.
I would think if you filled a roller with this stuff you would have to make sure the frame and bearings could handle the total load.
   / Lawn Roller: Fill w/other than H20? #15
It seems to me that is pretty dense stuff but I would think the tank would dent easier because it is like mud. Food for thought though.
Looks like it has been well over a year since I did this. It worked out fine. If memory serves, it ended up being about 1750lbs. I use it to compact the driveway after I box blade it. Works great!
   / Lawn Roller: Fill w/other than H20? #17
Wouldn't it be awsome if you turned a lawn roller into an ice cream maker !!! Then I could tell the old lady, quit hassling me Im'e makeing Ice Cream ;)
   / Lawn Roller: Fill w/other than H20? #18
Since my drum is steel, should we coat the inside with oil before adding concrete to help prevent the concrete from deteriorating the rollers integrity>
Grundfos Centrifugal Pump (A50121)
Grundfos...
1996 John Deere 7210 (A50120)
1996 John Deere...
2018 Nissan Titan Crew Cab Pickup Truck (A50323)
2018 Nissan Titan...
17604 (A51694)
17604 (A51694)
2001 John Deere 670C Motor Grader (RIDE AND DRIVE) (VERY NICE) (A50774)
2001 John Deere...
20303 (A51694)
20303 (A51694)
