Lawn Roller: Fill w/other than H20?
   / Lawn Roller: Fill w/other than H20? #11
The concrete would make a fairly heavy roller but fwiw,, filling with weight material for drilling mud would be almost twice that. Bayrite weight material comes in at 36lbs/gallon, that would make this a 3000 lb roller. 100lb sacks of this stuff are tiny compared to things like fertilizer.
I belive i have this figured at approximately 1650lb +/-. I am a litle concerned on some parts of the gravel driveway the slop might be too steep for this. But I guess I could pull it behind my '79 FJ40 if that were the case.
I was suprised at how many bags it would take!
   / Lawn Roller: Fill w/other than H20? #13
Does that harden like concrete, and I assume it does, but what does that cost roughly compared to concrete. That sounds like something I have to remember.
   / Lawn Roller: Fill w/other than H20? #14
This is more like stone dust, doesn't harden but makes a very heavy mud that will settleout quickly in water. Since it is used in the oil field I haven't ever had to buy it.
I would think if you filled a roller with this stuff you would have to make sure the frame and bearings could handle the total load.
   / Lawn Roller: Fill w/other than H20? #15
It seems to me that is pretty dense stuff but I would think the tank would dent easier because it is like mud. Food for thought though.
Looks like it has been well over a year since I did this. It worked out fine. If memory serves, it ended up being about 1750lbs. I use it to compact the driveway after I box blade it. Works great!
   / Lawn Roller: Fill w/other than H20? #17
Wouldn't it be awsome if you turned a lawn roller into an ice cream maker !!! Then I could tell the old lady, quit hassling me Im'e makeing Ice Cream ;)
   / Lawn Roller: Fill w/other than H20? #18
Since my drum is steel, should we coat the inside with oil before adding concrete to help prevent the concrete from deteriorating the rollers integrity>
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
New/Unused 7ft 10 Drawer Work Bench (A51573)
New/Unused 7ft 10...
2018 FORD F-150 (A52472)
2018 FORD F-150...
1998 INTERNATIONAL 9400 (A52472)
1998 INTERNATIONAL...
2015 Jeep Compass Latitude SUV (A50324)
2015 Jeep Compass...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
