TuffTorq K46 Repair Guide with Pictures
   / TuffTorq K46 Repair Guide with Pictures #111
2manytoyz,
Mine also seemed loose. I think it may be due to the fact that the cover is off. I've only mowed lawn with mine. I did the rebuild and have it posted on youtube.
If any one who watches that has already successfully rebuilt and sees anything wrong please let me know.
I am going to reinstall and hope for the best.
YouTube - Part 2 - K46 Rebuild
   / TuffTorq K46 Repair Guide with Pictures #112
It worked! Thanks to this post I am officially mowing. :)
The Hydro is powerful again and it's very quiet. Before it would wine terrible.
At first it did nothing when i fired the engine up and I was really nervous. I then read directions for priming the drive and I was off to the races!
Thanks again!
   / TuffTorq K46 Repair Guide with Pictures #113
Many thanks for video. May I have a question? Does tractor have a same pomer (torque) in both directions (forward and reverse)? My tractor, when I go reverse to the hill after 2-3 meters it lose the torque, but in forward directions it doesn't have any problem.
Thanks.
   / TuffTorq K46 Repair Guide with Pictures #114
This is clearly the best thread anywhere on how to perform this repair !
So I'm about to undertake the job and was just wondering ... one thing about this transmission that annoys me is that there is no drain plug on the unit. Since the unit will be apart, has anyone ever drilled and tapped a hole for a drain plug ?
Mike
   / TuffTorq K46 Repair Guide with Pictures #115
I returned my K46 to a fellow at the Tuff Torq factory to have it upgraded to the heavy duty K57. It cost much less than a new K57 or a rebuilt K46.
   / TuffTorq K46 Repair Guide with Pictures #116
Mike
You would have to drill and tap a fill plug too then right?
   / TuffTorq K46 Repair Guide with Pictures #117
I got my JD 155C used with 89.4 hrs on it. I bought it thinking its good to go with that little hours on it. Test drove it before I bought it and it seemed ok. Got home and drove it 20min and it starts slipping. I found this thread and ordered some parts. I have them on order now. I took the tranny apart tonight to find I will need more parts. Someone has had it apart before. And assembled it wrong and messed up a few things. Now there are metal bits in there that have got into the bearings. So most of them need to be replaced. Also the final reduction gear and pinion shaft are shot. Someone installed them wrong and they wore on one side more leaving play and bits of metal have been scrapped off the shaft and inside of the gear. Also they smashed the filter on one side and that left an opening for the metal bits to go through it.
:mad:
   / TuffTorq K46 Repair Guide with Pictures #118
Thanks LOGG!!! just "Rebuilt" my K46 last night and the tractor is running better than ever.
One question though: The tranny still whines a bit (although seems to be getting better over time). Is that normal?
The thing pulls like it never has for me (I bought it last year and it already had "the problem").
Thanks again for this awesome tutorial...
Thanks as well to GixxersRevolt for the Youtube video... this helped alot too.
- sean
   / TuffTorq K46 Repair Guide with Pictures #119
Thank you LotsofGreenGrass for the K46 repair guide. I have a question about the little rod that slips out from the motor cylinder, as mine did, but did not see where it came out from but looks like the very end of the shaft that seats in the transmission case housing? Not sure but do not want to reassemble until I am sure. Does it sit at that bottom in the cavity below the shaft?
Thanks!
JWolf634
New/Unused CFG Industrial XZ20R Mini Excavator (A51573)
New/Unused CFG...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2021 Ram 1500 Bighorn (A53472)
2021 Ram 1500...
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
2014 Club Car Electric Utility Cart (A51691)
2014 Club Car...
