TuffTorq K46 Repair Guide with Pictures
   / TuffTorq K46 Repair Guide with Pictures #101
Well my grass is way tall and I just don't have the time to do this rebuild and the wife is saying to just take the mower to JD and let them change out the tranny. I would really like to see the rebuild on You Tube....and I don't mind the language because I will be right there with you! Thanks to everyone on that has posted up.
GixxersRevolt-mine is a 2002 X300 with about 200 hours on it and has been a great mower as well. I just have to fix the tranny and get back to mowing. What did you pay for the parts?
Yellow76
I paid a total of $181 and change with shipping.
Parts will be here on Monday according to UPS tracking number. I am going to do the tear down and cleaning this weekend. I'll try to post video before Monday.
My mower is a 17.542HS Sabre. Not sure if it is the same setup as yours but if it is the removal and install is pretty straight forward. Could save you some considerable labor $ if you go the route of installing yourself.
I'll try to find some time to throw a video up for the removal and install too.
   / TuffTorq K46 Repair Guide with Pictures #102
Looking forward to it. Good luck and keep us posted.
   / TuffTorq K46 Repair Guide with Pictures #103
Hi Yellow. Like you, I didn't have the time to do the rebuild myself. I considered replacing the tranny with a new unit as your wife is suggesting, but I found out about the rebuild options and then about Duane Deardorff at Tuff Torq doing the rebuild on the side for customers.
Essentially he installs the T46 rebuild kit you can buy from Tuff Torq ($374) and if you desire, adds a T57 upgrade kit. The basic rebuild was $475.00. The T57 upgrade added $89.00. They can send you a pre-configured shipping box for an additional $13, which I used. That comes to $577. That does not include the cost of shipping the unit down to them, but it does include UPS ground return shipping. These were prices Duane quoted me in December, so I don't know if the fuel increases have changed his prices since then. A generic new K57 on the Tuff Torq site lists between $800 and $900 (not sure how it is configured), and a Simplicity spec'd K57 is $1018. If you read the Tuff Torq literature, the K57 is the same basic unit as the T46 just enhanced for additional durability and rated for a larger set of tires. You get an oil drain port and a charge pump for starters - not found in the T46.
I figured the additional upgrade cost and $100 for letting someone else do the work of installing the rebuild kit were worth it especially when compared to the price of a new build K57. A new K46 goes for over $600 and it is still a K46. I figured letting someone do the work to upgrade me to a K57 for about the same amount as a new K46 was worth the investment. Of course, if you have the time, you save a bunch doing it yourself.
Here's a link to show the work Duane did for me. The one item not normally included is the bottom case which he apparently cracked while taking my unit apart.
https://picasaweb.google.com/104657432962935815611/MyJDL118?authkey=Gv1sRgCOvz66y3qajfrAE&feat=directlink#
Good luck!
   / TuffTorq K46 Repair Guide with Pictures #104
Great thread I tore down my 727 hr. K46 tonight. Hav'nt got to removing the 3 bolts inside bottom case yet. Orderd parts from tuff torq thursday so hopefully they will be here by tuesday this week. I will post how it all turns out. I never would have tried this without this post.
   / TuffTorq K46 Repair Guide with Pictures #105
Wow! I thought the K46 in my 585HR 2002 JD L120 lasted along time .
I will order my parts this week , Wish me luck.
So does anyone have the ENTIRE list of parts I should order? I know everyone's situation is different , just looking to have it all in one order.
Thanks Desert
   / TuffTorq K46 Repair Guide with Pictures #106
Desert,
I just went through the ordering process last week and documented the process with parts list. I ordered the suggested parts list plus a few extra. (vent cap and sealing cap).
You should go to turf torq and look up your actual tranny model for ordering parts. If you don't want to order via the web you need to call them. The number is in the earlier posts provided by LotsofGreenGrass
https://www.tufftorqservices.com/EnvEElogin/html/login.html
Here is a link to the post detailing my order. My drive is a K46V.
http://www.tractorbynet.com/forums/2343378-post100.html
   / TuffTorq K46 Repair Guide with Pictures #107
I have recorded my k46 removal. I will post the video of the rebuild/repair and re-install in two additional parts after I do the work. I received the parts today but can't get to it today.
YouTube - Part 1 - K46 Transmission Removal
   / TuffTorq K46 Repair Guide with Pictures #108
Good Job, Nice helmet cam too! :thumbsup:
Desert
   / TuffTorq K46 Repair Guide with Pictures #109
Gtunney, thanks for the info. I am about at that point. I ll give TT a call and see what my prices come out to. I will weigh my options then. Appreciate all the info from everyone.
   / TuffTorq K46 Repair Guide with Pictures #110
Well I removed the housing tonight in center of trans.(3 bolts) I started to remove the big gear cluster then decided not. I tipped the trans forward then secured it there and began flushing out with brake cleaner. Most of oil and cleaner went out fill hole. The rest I soaked up with paper towels. I then turned down my compressor and started blowing evrything clear and dry. Tipped tranny carefully from side to side, front to back in the process. BTW, I have a lot of slop in the big gear cluster, is this normal? I use to pull a 1600lb. roller with this mower. Geras all looked good besides some very minor pitting on the smaller gears in front of the big gear.
2016 E-Z Beever M12R Towable Brush Chipper (A50322)
2016 E-Z Beever...
Mohawk 12,000lb Two-Post Electric Auto Lift (A51691)
Mohawk 12,000lb...
2015 Ford F-450 Flatbed Truck (A51692)
2015 Ford F-450...
2023 ACE SC804050L SANDBOX TRAILER (A54607)
2023 ACE SC804050L...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
