Craftsman DYS 4500 seat switch
   / Craftsman DYS 4500 seat switch #1
millwrightdude
I would like to know how to disable the safety switch under the seat.
   / Craftsman DYS 4500 seat switch #2
You have two choices. If unplugging the switch does not work, make a "jumper" to replace the switch in the wiring harness.
   / Craftsman DYS 4500 seat switch #3
Does the seat switch wiring go to the bottom center of the seat? If so, its like mine. Remove the seat from the mount, remove the switch from the seat, use a cable tie to hold the switch plunger depressed, lay the switch on top of the gas tank, remount the seat. The nice thing about doing it this way is if you want to restore the safety switch its just a matter of removing the cable tie and remounting the switch in the seat so save the mounting parts.
good luck
DanKtx
   / Craftsman DYS 4500 seat switch #4
I also have a safety switch problem, I think. The engine starts right up, but when I either engage the blades or release the clutch pedal the engine stops. I though that maybe it was the ignition swich, but now that I have read the post's, maybe it;s the seat switch. I did find the safety swich by the clutch pedal and jumped it, but it would not even start. I did notice that the switch under the seat looks bad, but, I did not jump that one yet. Were is this third saftey switch that you guys are talking about?
I followed the wiring harness all the way to where it pugs in near the starter. I unplugged it and that did the trick
   / Craftsman DYS 4500 seat switch #6
i had that exact problem on mine last year, turned out to be a relay that most of the switches go to, replaced it and no more problems.
   / Craftsman DYS 4500 seat switch #8
But, the switch has 5 wires going to it. The center wire is black. Now, how do you jump the switch?
2007 Caterpillar 262C Compact Wheel Loader Skid Steer (A59228)
2007 Caterpillar...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2013 CATERPILLAR 950K WHEEL LOADER (A60429)
2013 CATERPILLAR...
2016 CATERPILLAR 311FLRR EXCAVATOR (A60429)
2016 CATERPILLAR...
2025 CFG Industrial NT20-CZ Mini Excavator (A59228)
2025 CFG...
2020 CAT 308 (A53317)
