Help with shear pin info
   / Help with shear pin info #1
houstonscott
Elite Member
Oglesby, Texas
Kubota L3800, Kubota GR2120, Kubota RTV1100, Kubota 5100sc
New here, broke a shear pin on a Howse 6' HD mower. It's just a steal bolt type of pin. Need to know what grade it is and how long. It appears to be 1/2" stuff. Can't find it anywhere. Help. Oh didn't run over anything I think I just engaged the PTO a little over idle and it broke or I may have throttled up a bit to fast and it broke.
HS
   / Help with shear pin info #2
I think most shearpins for brush hogs are Grade 2 and 1/2 X 3 1/2. Check your owners manual or call Howse to be sure. Ken Sweet
   / Help with shear pin info #3
I have run my Howse mower for years with grade 5 (3 marks) bolts as shear pins. I make sure the unthreaded shank portion of the bolt is long enough to go through the yoke.
   / Help with shear pin info #4
I have replaced shear bolts in my rough cut also only occasionally though and grade 2 bolts are tough to find and is what I believe is spec on them.
I have a grade 5 in mine and haven't replaced it since but I am careful when driving over saplings etc.
I have seen grade 2 bolts at the farm store you have to look to find a bolt with no markings thats a grade 2.
   / Help with shear pin info #5
I think the rule is like grade 2 for less than 40 hp and over that use a grade 5.
Great info, got to love TBN. The tractor has 57hp and maybe why I broke it so easy. Looks like I should buy half a dozen when I find them. Thanks..
HS
   / Help with shear pin info #7
With that kind of horsepower I recommend upgrading to a slip clutch. I think you have more torque from the tractor and a fair amount of centrifical force from the 6 cutter. I have a slip on the cutter but have had shear bolts on a few other implements and use grade 5 except for an old single bottom moldboard. It prefers the lower grade, although a punch is needed to get the broken softies out.
   / Help with shear pin info #9
HS
check your manual.. it's in there. my howse manual lists mine.. and howse manuals are downloadable.
IMHO.. I'd go grade 2 for gearbox and pto clutch safety.
soundguy
   / Help with shear pin info #10
Tractor Supply has grades 2, 5, 8.
larry
2014 DORSEY EXPANDABLE FLATBED (A59575)
2014 DORSEY...
2017 CHEVROLET SILVERADO 2500HD (A58214)
2017 CHEVROLET...
2018 Chevy Silverado 1500 4X4 (A56438)
2018 Chevy...
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
DEUTZ MARATHON...
MASSAGE CHAIR (A58214)
