Seat up, can't run rear PTO Chipper
   / Seat up, can't run rear PTO Chipper #1
mow4fun
Flemington, NJ
Well I hooked the chipper, flipped the seat up, set brakes, engine still running, and then it stalls/dies if I attempt to engage rear PTO for the chipper. I was able to do this last year with no issues and worked great.
I had my son sit on the seat while I finished chipping a pile of sticks and branches but that won't work again. :)
Any ideas?
Thanks
Last year, I never changed it and left it engaged and it worked fine but I tried to put it into nuetral and still no luck.
   / Seat up, can't run rear PTO Chipper #4
Simplest solution..... remove the spring under the seat. ;)
(while you diagnose the safety switch....... obviously ;))
I like my springs... :)
   / Seat up, can't run rear PTO Chipper #6
Make sure the mid-pto is off. That has gotten me before.
   / Seat up, can't run rear PTO Chipper #7
I had that issue when I first tried to run PTO attachments. For me, the PTO only position lever did not move far enough forward to press the safety switch sufficiently. I added a rubber bumper and that solved the problem.
   / Seat up, can't run rear PTO Chipper #8
I have a tlb, On mine I spin the seat around to face the back for the PTO to work
   / Seat up, can't run rear PTO Chipper #9
I found it a PITA to rotate the seat around each time I used the chipper. So I installed a hidden bypass switch just for chipping. It's wired in parallel to the safety switch.
   / Seat up, can't run rear PTO Chipper #10
Do you have a pic or more info? I would like an option like this.
2017 Bayliner VR5 21ft Bowrider Boat with 29ft T/A Boat Trailer (A51694)
2017 Bayliner VR5...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
BUYER'S PREMIUM INFO LOT NUMBER 2 (A53084)
BUYER'S PREMIUM...
2013 Dodge Charger Sedan (A51694)
2013 Dodge Charger...
2025 K2223 UNUSED Double Garage Metal Shed (A53117)
2025 K2223 UNUSED...
Case CX160C Hydraulic Excavator (A51691)
Case CX160C...
