2500 PSI Cylinder on a 2750 PSI system ??
   / 2500 PSI Cylinder on a 2750 PSI system ?? #1
crash325
Elite Member
Tucson AZ
New Holland TC-45
I'd like to hear from the experts on this. Will a 2500 PSI cylinder hold up on a 2750 PSI system??
   / 2500 PSI Cylinder on a 2750 PSI system ?? #2
Most manufacturers use a 4:1 safety factor. 10% over should be fine.
paul
   / 2500 PSI Cylinder on a 2750 PSI system ?? #3
paul
Burst test at 4:1 factor....
It is a warranty and liability issue....
Most cylinders experience a lot higher pressure than rated, when there are induced pressure spikes....even though these spikes are very short in time....
If there were no pressure spikes, the safety factor could be lower than 4:1....
If that cylinder do not have to operate at 2750psi, you can always use a work port pressure relief valve, set at 2500psi, to protect the "underrated" cylinder.
   / 2500 PSI Cylinder on a 2750 PSI system ?? #4
Or spend the extra few bucks and buy a 3000psi cylinder. It isn't like they are hard to find.
   / 2500 PSI Cylinder on a 2750 PSI system ?? #5
Shortened life span, and not much shorter with a difference of 250 psi
Save your $, wear that one out then replace it with 3000 psi unit
(though I doubt it'll wear out). As mentioned, Its not going explode.
my 2c
SCALES & PEA (A58374)
2014 Kaufman 12,000 Lb. Trailer, VIN: 5SHFD2223EB000633, Tandem Axle, Wood Deck, Tilt Deck, Asset# (A59076)
2014 Kaufman...
huqvarna trak star 1270 rail demo saw (A56435)
huqvarna trak star...
1994 Blue Bird Command Center Bus (A55973)
1994 Blue Bird...
2014 POLAR TANK TRAILER CRUDE TRAILER (A58214)
2014 POLAR TANK...
LOT: (7) Wheel Loader Shanks (A59076)
LOT: (7) Wheel...
