2500 PSI Cylinder on a 2750 PSI system ??
   / 2500 PSI Cylinder on a 2750 PSI system ?? #1
crash325
Elite Member
Tucson AZ
New Holland TC-45
I'd like to hear from the experts on this. Will a 2500 PSI cylinder hold up on a 2750 PSI system??
   / 2500 PSI Cylinder on a 2750 PSI system ?? #2
Most manufacturers use a 4:1 safety factor. 10% over should be fine.
paul
   / 2500 PSI Cylinder on a 2750 PSI system ?? #3
paul
Burst test at 4:1 factor....
It is a warranty and liability issue....
Most cylinders experience a lot higher pressure than rated, when there are induced pressure spikes....even though these spikes are very short in time....
If there were no pressure spikes, the safety factor could be lower than 4:1....
If that cylinder do not have to operate at 2750psi, you can always use a work port pressure relief valve, set at 2500psi, to protect the "underrated" cylinder.
   / 2500 PSI Cylinder on a 2750 PSI system ?? #4
Or spend the extra few bucks and buy a 3000psi cylinder. It isn't like they are hard to find.
   / 2500 PSI Cylinder on a 2750 PSI system ?? #5
Shortened life span, and not much shorter with a difference of 250 psi
Save your $, wear that one out then replace it with 3000 psi unit
(though I doubt it'll wear out). As mentioned, Its not going explode.
my 2c
2005 International 5900i T/A Flammable Liquid Transport Truck (A55973)
2005 International...
2016 INTERNATIONAL DURASTAR 4400 (A58214)
2016 INTERNATIONAL...
Stanley hydraulic power pack (A56435)
Stanley hydraulic...
Hyster H155 XL Forklift (A59213)
Hyster H155 XL...
2020 Husqvarna YTH22V46 46in Riding Mower (A56859)
2020 Husqvarna...
NEW Landhonor 9200LB Ratchet Binders & G70 Chains (A59000)
NEW Landhonor...
