HELP! 2007 Dodge 2500 4low works, but no 4hi
   / HELP! 2007 Dodge 2500 4low works, but no 4hi #11
It sounds like the shift solenoid is out of whack or the shift fork.
Chris
   / HELP! 2007 Dodge 2500 4low works, but no 4hi #12
that's one thig I was thinking.. solenoid.. it's what was sticking on my gmc..
soundguy
   / HELP! 2007 Dodge 2500 4low works, but no 4hi #13
I'm thinking solenoid too. Good luck!
try driving backwards, then forewards and then shift to N and then try to engage it.
had to do that once onmy yukon that has the shifter button on the dash.. hadn't used 4wd in a while and it got sticky.
I like my dodge 1500 with shifter on the floor.. no doubts about when / if it shifts :)
soundguy
I have tried it everyway possible. I hear the xfer case making the noise like it does when it shifts but still nothing. I don't know if that is good or bad. :confused:
I guess next I will change the fluid (needs doing anyway) and check for metal.
   / HELP! 2007 Dodge 2500 4low works, but no 4hi #15
If your truck is a 2007.5, is it still under coverd under the bumber to bumber policy????:confused:
   / HELP! 2007 Dodge 2500 4low works, but no 4hi #16
It would actually be the powertrain warranty. He said he was out of warranty so I am guessing he has lots of miles.
Chris
   / HELP! 2007 Dodge 2500 4low works, but no 4hi #18
my 07 Dakota has a lifetime power train warranty he might want to check on that!! Not sure on the "real" trucks! :D
Chris
My truck has 78,000 miles. The person I talked to at the local dealer said that all I left under warranty was the engine itself. :(
   / HELP! 2007 Dodge 2500 4low works, but no 4hi #20
I would look into that. I though that era of Dodge had 10/100,000 mile powertrain warranty.
My 03 had a 6/60,000 mile I think and I got a tranny replace at nearly 40,000 miles.
Where is Dmace when we need him?
Chris
2012 PETERBILT 337 (A58214)
2012 PETERBILT 337...
2014 Chevy Malibu Sedan (A56859)
2014 Chevy Malibu...
2017 RAM 2500 (A58214)
2013 Ford F-750 Pak-Mor 16 Yard Rear Loader Garbage Truck (A56858)
2013 Ford F-750...
2019 CAT TL1055D (A58216)
2019 CAT TL1055D...
Pull Type Concrete Mixer (A57453)
Pull Type Concrete...
